Hi guys, looking for second hand decent examples of the above. Rather not drop the full whack for them on mx5parts if possible.
Ta.
K&N filter and cat bypass pipeHi guys, looking for second hand decent examples of the above. Rather not drop the full whack for them on mx5parts if possible.
Ta. '92 1.6 Eunos BRG
Re: K&N filter and cat bypass pipeYou need to give more information than that Dude. What type of K&N filter are you looking for ? A standard air filter box replacement or a cone filter, or for a Turbo/Supercharger setup then what size/shape are you looking for to fit there ?
For the Cat Bypass - is it Mk1 or for a Mk2 ? There are loads of ones out there all of different sizes. Hey, I'm just trying to help you get the correct parts that you want ![]()
![]() Re: K&N filter and cat bypass pipekeep in mind that the decat can be very noisy ,I have a new one just fitted but thinking of going back to a cat and the decat is supposed to be silenced! looks really good s/s ,but toooooo noisy
Mine wont fit your car as its for a 1.8 english mk1 Keep the noise in mind ,have a f&n cone as well,prob dosent help. Same "power" increase is achived by drilling 2 large holes in base of standard fliter box and fitting f&n panel filter. Best of luck Brian ]96 na Merlot edition. sold
Re: K&N filter and cat bypass pipehi turismo,jason here,yourself and your dad got the v spec off me.
great to hear he has got stuck in and has lots done. now your looking for a k+n filter,there ok,but ive even better a apexi filter with proper adapter to afm and heat shield and mounting kit. dont have the pipe,and as the others say there noise. your dad said you would be intrested in strut braces,ive both under bonnet and rear cockpit braces. got a good few trick items if needed,short shift gear kit,jackson induction kit,momo race steering wheel mint and the best. sure give me a buzz on 086 895 30 80 for a chat,and you or your dad can drop up and look,buy ![]() have those 15inch wheels also,could do a bulk buy deal ![]() jay
Re: K&N filter and cat bypass pipeThanks guys. Sorry didn't think anyone bothered with box filter replacements so I didn't specify. And I imagine 99.99% of mx5s/eunos/miatas are naturally aspirated so again it never occurred to me to be more specific ;-p... Only kidding Fergus...your car is nothing short of awesome...I read your project build thread from start to finish....impressive! Not sure my misus would let me use my living room as a spray booth though.
![]() I've a 1.6 '92 eunos, which would make it a mk1/na. I'm aware the cat replacement makes more noise...merlot, is it really that much worse? I should prob have a listen to someone else's first then. Jay, I thnk your old cars getting a full respray and new hood at some stage. Saw it today. Fundamentally sound car. I'll give you a bell about the induction kit. Since I posted last night I've developed some ignition problems with my 1.6. I've not looked into it yet though. It's an intermittent misfire. Its bad on startup and can then come and go. I don't think it's the leads as when I disconnect them individually the cylinder drops for each one but it remains rough/lumpy afterwards. Haven't looked at plugs yet. I'll pop up another post if I can't figure it out. Btw, do you have photos of those rims by any chance? I'd sooner get my three year old daughter to successfully perform brain surgery than get an intelligible description from my old man. ![]() '92 1.6 Eunos BRG
Re: K&N filter and cat bypass pipeyes,give me a buzz 086 895 30 80 we talk then.
i had that missfire crack also,its the leads,they play funny tricks. yes when we talk,il get your number and il txt you a few pics. talk soon jay
Re: K&N filter and cat bypass pipeTry the leads but it may be the coil. Common fault. Therenare several different types but we have most in stock- 086 8226506
Re: K&N filter and cat bypass pipeYour welcome to listen to the decat on mine if you like, im based in clare where ,are you?
Re: K&N filter and cat bypass pipeJay/rob thanks. My dads gone nuts and bought another 92 1.6 today so ill pop home to new Ross and swap the coil pack etc. if its gone ill get a coil off ya rob. Think my dads going up to you to get a bonnet this weekend anyway.
Jay. I'll to ring tomorrow if I get a chance. I'm stuck at work most of the day so ill see. Merlot, I'm in cork so it's a bit of a hike. I'm sure ill just go ahead and regret it. Thanks guys '92 1.6 Eunos BRG
Re: K&N filter and cat bypass pipeWe have K&N cone type filter with fittings and lovely almost new stainless exhaust system for mk1.Also asst sets of alloys etc.086 8226506.Robert.Also lovely jap steering wheel (no airbag type) timber effect with leather trimming .
