Need Windscreen out to Fit Custom Cage
Postby Bert1150 » Sun, 12 May 2013 2:36 +0000
Hey all,
I have my mx5 booked in for a full custom cage next week and i need to take out the windscreen(perfect not broken) to fit cage. Does anybody know someone that can take out a windscreen an evening next week or next saturday ?
Car is is booked for the 19th for the cage and back to me on the sunday the 26th and ill need to get the windscreen back in before Wednesday the 29th as Im down in mondello.
Help!! :shock:
Bert1150
Re: Need Windscreen out to Fit Custom Cage
Postby MX5Spares » Sun, 12 May 2013 3:53 +0000
I usually take them out myself with Stanley type knife but only the type with the push out snap off blades as fully extended the blade i about 80mm long.You need that lenght in order to get in to corners etc.BUT BE CAREFUL--DANGEROUS IF IT GOES WRONG.Where are u based as any of the normal windscreen companies will remove and refit it for about 100e.ASAP windscreens is the lad I use to refit glass or for other cars. 087 2755121.Tell him Robert in Swords gave you the number.That is of course presuming you are local...!!!!
Postby Bert1150 » Sun, 12 May 2013 5:31 +0000
Thanks Robert,
Its dave here with the orange mx5, ill give thew lad a call in asap windows
thanks
Dave
Bert1150
Postby Bert1150 » Mon, 13 May 2013 3:50 +0000
autocheck wrote:I usually take them out myself with Stanley type knife but only the type with the push out snap off blades as fully extended the blade i about 80mm long.You need that lenght in order to get in to corners etc.BUT BE CAREFUL--DANGEROUS IF IT GOES WRONG.Where are u based as any of the normal windscreen companies will remove and refit it for about 100e.ASAP windscreens is the lad I use to refit glass or for other cars. 087 2755121.Tell him Robert in Swords gave you the number.That is of course presuming you are local...!!!!
hey Robert thanks for the link the guys are comign out this week
Thanks again
Dave
Bert1150
