Mk1 Roof Frame
Mk1 Roof Frame
Postby Paddyman » Fri, 03 Mar 2017 10:28 +0000
Hi,
Turns out that the roof frame on my Mk1 is probably from a Mk2 so the replacement hood I bought doesn't fit quiet right. Anyone have Mk1 frame only for sale?
Paddyman
Re: Mk1 Roof Frame
Postby 93 Mk1 » Fri, 03 Mar 2017 11:04 +0000
Try Robert (MX5spares) on here.
Re: Mk1 Roof Frame
Postby Paddyman » Fri, 03 Mar 2017 11:23 +0000
Sent him a message also, thanks.
Paddyman
Re: Mk1 Roof Frame
Postby MX5Spares » Fri, 03 Mar 2017 8:24 +0000
Both the same bar the extra strapping on rearmost bar to keep the bar pulled back so glass window does not sag due to weight of glass.Easily rectified with bit old car seat belt
Re: Mk1 Roof Frame
Postby Fergus » Sun, 05 Mar 2017 3:15 +0000
MX5Spares wrote:Both the same bar the extra strapping on rearmost bar to keep the bar pulled back so glass window does not sag due to weight of glass.Easily rectified with bit old car seat belt
That is not correct, the Mk1 soft top will not fit the Mk2 soft top frame - "The soft top by itself will not fit. If the entire soft top frame is replaced, it will. (The NB top has been successfully retrofitted to an NA frame, though it requires some modification" https://www.miata.net/garage/compatibility.html
Re: Mk1 Roof Frame
Postby MX5Spares » Sun, 05 Mar 2017 9:10 +0000
I have fitted several new soft tops to NA and NB and the actual soft tops are the same so the only difference between NA and NB frames are the two extra webbing straps needed to keep the rear frame overhead bar pulled taut as the soft top is closed .This is to stop glass window sagging due to its weight.Thats why you see few mx5,s with the rear glass window at 45degrees? rather than more upright position
Re: Mk1 Roof Frame
Postby Paddyman » Mon, 06 Mar 2017 11:11 +0000
This is what I got from the crowd that I bought the hood off of:
Yes the NA frame is different to the NB frame and we manufacture a specific hood for each frame.
The NB frame has a spring loaded rear bow that moves when the frame is folded back.
Paddyman
Re: Mk1 Roof Frame
Postby Fergus » Tue, 07 Mar 2017 3:26 +0000
Paddyman wrote:This is what I got from the crowd that I bought the hood off of:
Here's the springs used in a Mk1: http://www.mx5parts.co.uk/cable-tension ... -1182.html
Here's the springs used in a Mk2/Mk2.5: http://www.mx5parts.co.uk/cable-tension ... -1183.html
And here's the conversion kit to fit a Mk2/Mk2.5 hood onto a Mk1 frame (notice the extra material for the sides): http://www.mx5parts.co.uk/hood-conversi ... -4020.html
Paddy don't buy another frame, I'll take a shot at modding that hood first for you, I did it before so ;)
Re: Mk1 Roof Frame
Postby Real Rayzor » Tue, 07 Mar 2017 9:39 +0000
Paddy, tale a look in the free stuff section. Someone is giving away a mk1 hood frame. Should be perfect for you.
Real Rayzor
Re: Mk1 Roof Frame
Postby Paddyman » Tue, 07 Mar 2017 1:25 +0000
Before posting this I had checked to see if there were any about.
Its a bit of coincidence all right.
Could well be exactly what I need, thanks for the heads up.
Paddyman
Re: Mk1 Roof Frame
Postby Pogo » Wed, 08 Mar 2017 12:59 +0000
Not sure of your location, but spotted this one on adverts.
http://www.adverts.ie/12014721
Pogo
Re: Mk1 Roof Frame
Postby Paddyman » Wed, 08 Mar 2017 11:04 +0000
Wow they are coming thick and fast now.
Seeing as the hood has already been glued to the frame I think we are just going to keep at it and make it fit as best it can. That's what I have been advised anyway and as I don't know jack shit about it I'm gonna go with that advice.
Paddyman
Re: Mk1 Roof Frame
Postby Fergus » Thu, 09 Mar 2017 2:26 +0000
Paddyman wrote:Wow they are coming thick and fast now.
The impact glue is easy to remove without any damage to the hood because it's new and it hasn't been on the car/hood for years, it's all the rivets that have to be drilled out that create problems especially with the tension cables/springs (larger rivets to be used and cracks in the material can be expected etc). Any hood put on without the impact glue tends to wear/crack faster in places than the ones that have it - Mazda knew what it was doing in the factory and anyone that fits a hood on an Mx5 that doesn't use the impact glue is doing it wrong (take that issue up with Mazda yourselves – I’m not a hood fitter or a mechanic - it’s the ‘Mazda Fit’).
The hood you have right now fits perfect on the frame except for the rear section/rain rail. That’s the tiny little difference in the frames, hence the tiny little difference in the spring lengths between the Mk1 and Mk2 hoods – it fits the frame perfect but not on the car.
I’ve done this type of mod once before on a Mk1 with the exact same issue so I’d say I can sort this out for you – no fee/charge etc.
