Bought this tracking system from Ebay, it's the absolute biz !!
Basically, what it does is
- send you a txt message telling you GPS coordinates of where the car is located and what speed it is doing
- allow you to immobilise the engine via a text message
- warn you by txt if the car is moved outside of a certain area that you define via a txt message
Took me about 2 hours to fit it to the Jag, but would me about an hour or 90 mins on the MX5. Takes three wires minimum (earth, +12v permanent, +12v IGN/ACC) or 6 in total for a full installation (earth, +12v permanent, +12v IGN/ACC, -ve feed to immobiliser relay, feed to/from the car's existing alarm, and a wire to a panic button)
Also has a battery built-in so that it works still if the car's main battery is disconnected.
Some people won't care where their car is if it is stolen - if so, this device isn't for you. I have had something similar fitted to the MX5 for years, but bought this unit for the Jag.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330401610568
