injectors
Re: injectors
Postby Steve » Sun, 24 Jan 2010 8:57 +0000
charged_rs wrote:lc-1's need recalibrated from time to time , which is frustrating
I've wired up a button and LED to mine, only takes a sec now.
Re: injectors
Postby ger » Mon, 25 Jan 2010 9:40 +0000
mk2 and 2.5 injectors have a better spray pattern than the mk1 1,8 tantops
True. but 50 euro for low milage cleaned and flow tested tan tops or 130-150 for used later ones from autolink.
As far as i can see the Lc-1 has a much faster read out, AEM seems to be laggy although it is supposed to be easier to fit.
Did you buy the basic kit steve?
Is there a good analogue style gauge for the WBO2, i like the 52mm old style autometer round gauges.
Tested out a bit more boost on sunday, gave it 8psi, but after the 3rd run the stock clutch let go at 5000rpm in 4th. So back down to 6psi until i can pick up a stage 1.
fun while it lasted, oh a taste of honey...
Re: injectors
Postby Steve » Mon, 25 Jan 2010 10:39 +0000
ger wrote:As far as i can see the Lc-1 has a much faster read out
Yup and yup. Need to pick up a new serial cable though.
ger wrote:Is there a good analogue style gauge for the WBO2, i like the 52mm old style autometer round gauges.
You can program one of the analog outputs to display on a NB02 gauge as far as I remember..
ger wrote:Tested out a bit more boost on sunday, gave it 8psi, but after the 3rd run the stock clutch let go at 5000rpm in 4th. So back down to 6psi until i can pick up a stage 1.
heheh
Return to Turbo Talk
