base jrsc kit , 64mm pulley , aem fic , crap airfilter
its a bit quick
supercharged once more![]() base jrsc kit , 64mm pulley , aem fic , crap airfilter its a bit quick
Re: supercharged once moreNice, is that power at the wheels or engine ? I presume at the wheels, so about 223hp at the engine. Healthy.
My dyno graph has much the same shape and it's a ballbearing turbo ! Nice fat torque line at low RPM, peak power at 3,200rpm on mine, looks similar to yours. Is that a Jackson Racing SC with standard pulleys ? It's a small world after all. It's a small, small world
you know what mate, i never even asked if it was wheels or flywheel ? i reckon its flywheel tbh yup , its a sebring mazdaspeed kit , which is essentially the JRSC I swapped out the standard 67.5mm pulley for a custom made 64mm pulley. the standard pulley size for a 1.8 charger is 67.5mm , for a 1.6 its 72mm ![]() here are a couple of vids capturing the sound.....its really addictive and i keep forgetting to turn the radio on... YouTube - IMG 1591 [url="http://www.youtube.com/watch?v=WIDS7amTRqw"]YouTube - IMG 1588[/url]
Re: supercharged once moreThis is all perfectly clear to me
Re: supercharged once morenice, great sound
Is it stripped out too (745, is that KG?)?
Re: supercharged once morejust wondering could you post up a quick list of what is needed to fit this type of kit, and the modifications, if any, you need to do
before of after fitting. thanks. You som'bitches couldn't close an umbrella
