knock sensor
knock sensor
Postby ger » Wed, 14 Jan 2009 8:46 +0000
anyony using a bosch knock sensor.
Found this kit, any suggestions.
http://www.thor-racing.co.uk/KnockLite_ ... te_Kit.asp
Postby Steve » Wed, 14 Jan 2009 11:27 +0000
it looks like exactly the same sensor that comes with the LINK ECU, I've never had any probs with it..
Postby ger » Fri, 16 Jan 2009 9:00 +0000
how difficult are the to fit?
my plan is to set up a knock sensor, Bar & Plate IC, a walbro 190, some new discs for the vortec and 1.8 injectors. Should be good for 8 psi, dont want to look at clutches or diffs.
Postby Steve » Fri, 16 Jan 2009 9:55 +0000
theres a bolt (or a threaded bolt hole, can't remember, will get a pic later) on the side of the block near the oil filter. You just screw it in there.. 2 min job.
Postby ger » Thu, 29 Jan 2009 12:25 +0000
cool, thats the knock sensor sorted, now fir the IC.
Postby Steve » Thu, 29 Jan 2009 12:42 +0000
nice one! Did you go for the "red light" version?
Postby Geese » Thu, 19 Feb 2009 1:11 +0000
MAke sure you use a good torque wrench when installing knock sensors .
Geese
Postby ger » Fri, 20 Feb 2009 10:00 +0000
have one from aldi :D
Postby ger » Fri, 20 Feb 2009 10:01 +0000
seems ok
Return to Turbo Talk
