theses pics are probably more relevant to your set-up.
The turbo heatsheild is from flyin miata 60$ + pp
The air filter heastsheild i got on ebay for a tenner.
The ducting is 2 1/4 inch this will go down to the mouth in the nose cone, i used a u bend from an outside drain for the pick-up
Extra heat cloth from murray motorsport sold by the meter.
You should rap the AC pipes near the down pipe and the water bottle.
If you need vacuum tube for you boost gauge murray motorsports have 3m of silicone for about a tenner.
Where the air filter is located now is actually one of the cooler spots under the hood.
