Brake upgrade
Brake upgrade
Postby fabfiveferg » Thu, 28 May 2009 9:57 +0000
Figure doing something about the brakes might be a good idea with the extra power.
Any ideas on whether I should go for grooved discs (I see some Turbo grooved discs on MX5parts) or should i be looking to pick up some 1.8 calipers and discs second hand. Fooked if I'm paying for new ones. Far too pricey
Re: Brake upgrade
Postby franksm » Thu, 28 May 2009 10:33 +0000
Go for the 1.8s
Converting to drilled/etc disc on the 1.6 is only going to give marginal improvement. The 1.8s are a bigger size, bigger surface area so are already at an advantage.
Just don't go for Greenstuff pads, or you'll need to buy a helper-monkey to scrub the cack off the wheels every other day.
Re: Brake upgrade
Postby Geese » Thu, 28 May 2009 11:35 +0000
Like frank said go for 1.8s
Geese
Re: Brake upgrade
Postby fabfiveferg » Fri, 29 May 2009 9:02 +0000
Thanks lads. I'll get on the trail of some 1.8 calipers so
Re: Brake upgrade
Postby Steve » Fri, 29 May 2009 10:30 +0000
Theres something about only needing the caliper brackets to do the conversion.. not the calipers themselves.. and then something about putting the rear right on the left and the left on the right .... or was it the fronts.. :? ;-)
Aha heres the link
http://www.bigllama.com/miata/brake/bigbrake.htm
Re: Brake upgrade
Postby Steve » Fri, 29 May 2009 10:45 +0000
Return to Turbo Talk
