Fuel pump on turbo mx5sHas anyone's fuel pump given up on their turbo or supercharged cars? I've a feeling mine is after going, will be checking it for sure tomorrow, I was driving pretty hard up through the gears earlier and in 5th gear it started losing power and died, it started again but was missing and cut out when I went to pull off, I couldn't hear the fuel pump priming up when I turned on the key (could always hear it before) and it wouldn't start again. A friend told me they can give up trying to pump alot more fuel and since I've 330cc beams injectors (around that) and about 200bhp (maybe more) plus the cars 23 years old I've a feeling it's gone.
Re: Fuel pump on turbo mx5sit could well be gone. Have you tried grounding gnd and ten in the diagnostics box? The fuel pump should run then.
If it does, you might have a sticky relay.
Re: Fuel pump on turbo mx5sNo il try that tomorrow, I've a friend that was calling out anyway tomorrow too and he has an uprated aftermarket fuel pump his not using on his rx7 so his bringing that we'll swap it if it is gone
Re: Fuel pump on turbo mx5sCheck your fuel tank for rust. This will eventually put an end to your pump.
Re: Fuel pump on turbo mx5sWe might have fuel pump if your stuck.Possibly 1.8 might have more output ??Or from 140bhp car ??
Re: Fuel pump on turbo mx5sThanks lads, il let ye know how I get on later
