So I've picked up a few bits for my turbo build, namely a T28, Intercooler/piping, lines, boost gauge, manual boost controller, BOV..
I'm going to be getting a manifold and down pipe setup off Sturovo on here, along with the gaskets and braided lines.
This is for a 1.8 mk2 Nardi, 140bhp
The parts I need more info on are as follows: (NOTE: I'm going to be looking to run at least 200bhp when all done and dusted)
Injectors
To keep the car running safe boost, I'm not convinced the stock injectors will run the kind of power I want. What injectors would you guys recommend for a 200+bhp power level? Currently looking at these:
http://www.ebay.ie/itm/INJECTORS-DENSO- ... 19bcc9143f
ECU
This is where I'm a little clueless.. I have no idea what ECU to go for, let alone where to source one. I've heard lots of good things about the MS2, but where can I pick one up? Also, would it be better to see about getting it mapped before it goes on the car? Is there someone on here that can do that?
Alloy Rad
I recently got a lot of work done to the engine, including a replace of the head gasket, water pump, and timing kit. But I think for safety I should look into a nice Alloy rad, possibly from Driftworks. Any opinions on other ones that would be worth going for?
Fuel Pump
I'm not sure of the power of the stock pump, so I think a bigger, better one is in order. I have a friend who says he has a spare one from his old GTST R34.. I don't know if this would actually fit though, so any advice on what pump could suit would be greatly appreciated.
This leads me nicely into..
FPR
What decent aftermarket FPR's are there out there for these cars? These are something I've never heard being spoken of in the same sentence as MX5. Maybe I'm just in the wrong circles.
Incase you want to see the kit I currently have, here's a link to my build thread:
viewtopic.php?f=39&t=6104
Sorry for the long post, but you can understand that I want to be thorough about what parts I get for this. So in that respect please tell me if I'm on the right track or wrong. Any advice you guys have is welcome.
