Wideband O2 sensor location?
Postby davith501 » Wed, 25 Mar 2015 7:24 +0000
Can I use new o2 sensor in the same place as the oem one or should I get it moved closer to the cat to get more accurate read? Thanks
Icon
RS
Mk1
davith501
Re: Wideband O2 sensor location?
Postby Steve » Wed, 25 Mar 2015 9:24 +0000
are you putting in a turbo or supercharger? Think you mentioned a supercharger at some stage yeah? :-)
If so, then yes, no harm in moving it further away. If not, then just stick with the oem 4 wire sensor.
Postby davith501 » Wed, 25 Mar 2015 10:30 +0000
It's a supercharger. Have Ms3 and got aem wideband in today. Makes sense to move it down really and will give a chance to wrap headers as well.
Icon
RS
Mk1
davith501
Postby [L'e$kro] » Sat, 20 Jun 2015 2:41 +0000
I would just replace the existing sensor. Sure it doesn't do harm to move it further, but it doesn't help either, so no point for the extra hassle of adding a bung.
Nico
[L'e$kro]
Postby emarkey » Fri, 26 Jun 2015 1:51 +0000
Guys,
In an n/a car, is it ok to just throw it in where the oem O2 sensor is? I cant see why not, just making sure.
emarkey
Postby [L'e$kro] » Sat, 27 Jun 2015 9:32 +0000
Yes, no problem. If you intend to run the wideband with the stock ECU, most of THE Wideband kits have a narrowband-style output so you can keep the feedback to the stock ECU
[L'e$kro]
Return to Turbo Talk
