Hi everyone
People often wonder how to turbocharge an mx5. Instead of replying individual questions, why not compile a parts-list?
It can be done for fairly cheap if you can make some of the parts yourself. It's time vs cost really, but first check if your budget and fabrication skills match your expectations before you start and turn it into a money pit or unfinished project
I'll cover the early 1.6 MK1 first, please chime in for 1.8 MK2 stuff.
Also there are many ways to skin a cat, the parts listed here are only a suggestion and provided as it. I'm no guru and just made mine this way. Yes, you certainly can have a bigger or smaller turbo, a water to air exchanger or no intercooler at all, water injection etc... Here is a recipe for 200whp on standard internals, but it can defo be done differently or with different results.
To spread the costs and avoid having the car off the road for too long, you can upgrade the fuelling while the car is still N/A, and gather or fabricate other bits in the meantime.
Fuelling
Aftermarket management
-From DIYAutotune:
Megasquirt Plug And Play (assembled kit) "MSPNP"
Megasquirt DIYPNP (unassembled kit)
You'll also need an Inlet Air Temperature sensor and its bung to be able to get rid of the Air Flow Meter
-From ExtraEFI:
http://www.extraefi.co.uk/MX5.html
Air Fuel Ratio/Wideband kit
Several brands out there:
AEM Innovate PLX etc..
Injectors
They need to flow enough for your power goals. there are calculators online for this.
I got mine second hand. Mazda Rx8 450cc/min yellow injectors from the 6port "sport" engine, and they are in their comfort zone at ~80% duty cycles.
Alternatively:
RC 440s
Turbo
Turbocharger
Mine is a Holset HX25, but that's pretty close to a TD04-13t. You can get a TD04-15t on Saab Aero models, with a T25 inlet flange. Turbo sizing and budget would require a separate topic I guess, so i won't go into details for now.
Air filter to match your turbo
Exhaust manifold
Has to suit your turbo's turbine housing inlet flange.
DIY route:
I made mine from Schedule 40 mild steel thick pipe. Purchased the flanges from eBay at QPS.
Vendors:
ARTech
If your turbo has a T3 footprint, there is a cast iron one you can search on eBay "1989-1993 MAZDA MIATA EUNOS ROADSTER 1.6L B6 CAST IRON TURBO MANIFOLD T3/T4"
Downpipe
Has to suit the bolt pattern of your turbo's exhaust flange, and fit your exhaust's 3 bolt inlet flange if you are on the standard exhaust. Also made mine from a bare flange.
Oil feed
Got mine here
Oil return/drain
Got a "Turbo Oil Drain Line Garrett T3 T4 35cm 10AN Teflon" from the same shop as above, but item no longer available.
You will also need a drill and tap for the sump to match the fitting of your drain..
Cooling
Intercooler
I bought that on eBay: "FMIC FRONT MOUNT TURBO INTERCOOLER 550x225x64MM 2.5" for £65, but the listing has expired. Pretty good fit on my MK1
Intercooler piping
Made mine from stainless 2.5" dairy piping. Bends cost around 7€ each from the top of my head, straight pipe is quite cheap.
Intercooler silicone couplers
...to suit 2.5" piping. Bought from Apex Motoring on eBay
3x "2.5" To 2.5" 4 Ply 90 Degree Turbo Silicone Coupler Hose Pipe" (at the intercooler and throttle body)
3x "3ply 2.5" to 2''inch Straight reducer 76.2mm SILICONE HOSE COUPLER PIPE" (from the turbo's air compressor 2" outlet)
Clamps for silicone couplers
Got mine from Apex-Motoring as well:
8x "2.5" inch Turbo Pipe Hose Coupler T-bolt Clamps Stainless Steel 67/75mm"
1x "2" inch Turbo Pipe Hose Coupler dual T-bolt Clamps Stainless Steel 54 to 62mm" (for the compressor outlet at the turbo)
Alternatively, a plug and play kit is available from Fast5 here
Optional/supporting mods:
-Big bore exhaust
-Spark plugs. NGK BKR7E (new ref is 4644) or BKR7EIX (Iridium)
-1.8 flywheel
-1.8 clutch assembly. Just bought a paddle clutch disk from XTD, seems to hold well so far.. Alternatively: Flyin Miata clutch
-1.8 oem Torsen diff
-Exhaust Gas Temperature thermocouple sensor and 0-5v converter.
-BMW e36 Variable Throttle Position Sensor.. PM Rhysmate for this adapter
-Coil On Plugs ignition conversion, using Toyota 1.8 VVTi COPs
-Dump valve
-MazdaSpeed engine mounts
Resources - Useful links
http://miataturbo.wikidot.com
Flyin' Miata Instructions
Feel free to add your input below!
Nico
