buying turbo setup
buying turbo setup
Postby andrew1219 » Tue, 05 Jun 2018 9:14 +0000
hi all looking at getting tubs kit of someone there looking for 2,000. comes with injectors intercooler tg04 tuba struvo manifold, downpipes only thing its missing is Wideband which I think is needed ? don't know a lot about turbos so just wondering is this a good price thanks
andrew1219
Re: buying turbo setup
Postby andrew1219 » Tue, 05 Jun 2018 9:16 +0000
forgot to say it also comes with megasquirt 2 ecu
andrew1219
Postby Steve » Wed, 06 Jun 2018 3:05 +0000
many miles on it do you know?
Any play in the turbo? See if you can give the compressor wheel a wiggle, google this before you go see it.
Which injectors?
Wideband costs just under 200e at the moment, for example : https://www.fruugo.ie/aem-electronics-x ... 2lEALw_wcB
Postby andrew1219 » Wed, 06 Jun 2018 7:20 +0000
haven't been down to see it he says he's had it on car 3 years, is the Wideband essential ? as he's been using it without one. thanks
andrew1219
Postby Steve » Fri, 08 Jun 2018 12:15 +0000
If you take the car for a dyno tuning session they will use their own to set the parameters in the ECU, you might be able to tune offboost values with your existing narrowband sensor but it won't handle boosted values.
For the price of them, I'd get one. Might be no harm to budget for a clutch and possibly a diff in the not so distant future too ;-)
Postby andrew » Sun, 20 Jan 2019 10:20 +0000
Get the wideband.
2k is very reasonable for a full kit. Running without a wideband is risky for the engine not the turbo kit.
andrew
Return to Turbo Talk
