A German is trying to invade my Japanese territory
Re: A German is trying to invade my Japanese territory
Postby Pops » Wed, 21 Oct 2020 1:19 +0000
I do believe that the missfire count is electrical but I'm trying to rule out the easy stuff first, I've seen a post somewhere about a bad wire going to the coil causing the same problem
Postby Steve » Wed, 21 Oct 2020 1:35 +0000
Pops wrote:Doing the vacuum test now, 3 leaks found so far, one major one was because some idiot (me) never reconnected a breather pipe on the air box, small one at what I think may be a vacuum regulator and another at the airflow meter, got to fix all these and go from there
That wasn't the one that connects under the intake manifold by any chance?
Postby Pops » Wed, 21 Oct 2020 2:31 +0000
Hi Steve, no it was from the dipstick to the air box.
Fixed all the leaks now, I didn't do anything with the vacuum unit though as it turned out to be the actual vacuum pump, I think the vac leak from it might be a pressure relief so I left it alone for now, with the relief plugged and then retested I couldn't find any more leaks, I did check under the manifold where you mentioned Steve and seems to be all ok
This German is getting a bit annoying now as I had to take the mazda out so I could get the slk in the shed, now it's pissing rain on the poor mx5
Postby Pops » Tue, 14 Sep 2021 5:05 +0000
The German is gone, replaced by a hondaImage
2007 1.4 se, something has to take the empty space in the driveway
