Finding things to do during lockdown
Postby Pops » Mon, 06 Apr 2020 8:04 +0000
Have to keep looking for things to do to keep boredom away, can't think of anything to do with the mx5 but the slk needs a couple of things done even though I intended to just use it as is.
The main thing that was annoying me was the condition of the wheels so that's where I started yesterday. Sometime in the past the wheels were powder coated but it looks like it was a very poor job done on them,
serious problems trying to get the brake dust off the inside of the rims
, tried every household cleaner I could find, oven cleaner was about the best until I rembered that I had a lidl sand blaster
Re: Finding things to do during lockdown
Postby Pops » Mon, 06 Apr 2020 8:10 +0000
Pity I didn't think of the sand blaster before wasting time trying to clean the rims, sand blaster took only a few minutes for each rim
Also found out that the rims are for slk only
Postby Pops » Mon, 06 Apr 2020 8:21 +0000
Due to the terrible outbreak of sunshine I had to do all the work outside :D :lol:
After spending most of the day trying to clean the rims I only managed to get the front of one of them sanded
but there's no hurry, there's going to be plenty of time yet before things get better.
I'm hoping that the 2pack primer will be OK to use, the intention is to sand back as much of the cracked /destroyed powder coat and give it a few coats of primer and use a 2pack silver paint & laquer
Postby Pops » Tue, 07 Apr 2020 8:09 +0000
Another day of sunshine, got the rest of the sanding done
Masked up ready for the primer
After a couple of coats, now to let it harden up before prepping for paint
Postby Steve » Thu, 09 Apr 2020 10:14 +0000
I need to do this job again soon, how long do you let the primer dry yourself?
Postby Pops » Thu, 09 Apr 2020 10:44 +0000
Hi Steve, the primer I had was 2 pack, I thought I had plenty of it but it turned out there was only a bit in the tin, still, with probably a bit more hardener than recommended I had just enough for 3 coats. I left them until the following day before sanding them for paint, the primer was totally dry and sanded very easily
Postby Pops » Thu, 09 Apr 2020 10:49 +0000
After 4 coats of basecoat and as many again of lacquer
This is the colour I'd picked out about 6 months ago, big change from the standard silver but worth trying something different
Postby Pops » Thu, 09 Apr 2020 1:57 +0000
Baking in the sunshine, also fitted the Chinese center caps, I have them since last year along with the paint but only getting around to them now
Must say that the center caps are up to the usual Chinese standard but for €8 including delivery they will do perfectly
Postby Pops » Thu, 09 Apr 2020 6:30 +0000
All done now, even the wheel studs
Now I have to find something else to do
Postby Pops » Sat, 11 Apr 2020 8:10 +0000
Must be getting desperate now, bike was left in the old shed for about 10years until I got the new steel shed and was left outside for over 3 years since, spent the whole day trying to un seize the chain and cables etc in the vain hope that it could be returned to full working order so that it could be handed down to a younger grandson, ideally it needs new cables for the gears but they'll have to wait until things get back to normal
Postby Pops » Sun, 26 Apr 2020 2:06 +0000
A happy kid now, everything working except for the gears, new cables needed after lockdown
Postby Steve » Mon, 18 May 2020 8:54 +0000
missed your follow ups to this thread somehow... those wheels look great, how long did you leave between final paint coat and lacquer coat?
Nice work on the bike too :-)
Postby Pops » Mon, 18 May 2020 9:32 +0000
Hi Steve,I've already forgotten the amount of work that went into them but about 4 coats of basecoat, didn't take long to dry but I'd imagine I left them about an hour to dry, then hit them with about 4 coats of lacquer and left them till the following day
Postby Steve » Mon, 25 May 2020 9:22 +0000
nice one thanks!
I've done nothing with the fleet since lockdown... nothing. I've lots to do but have been too distracted by building stuff in the garden/shed :-)
Postby Pops » Wed, 27 May 2020 10:53 +0000
I'm sure that with the fine weather the building and outdoor work comes first
