Tyre Size Advice
Tyre Size Advice
Postby Pete JB » Mon, 15 Jun 2009 10:31 +0000
Hi Folks,
I'm just about to put new rubber on the car, but I noticed yesterday on the bit of info on the car door that the tyres should be as follows:
Front 185 60R 14
Rear 195 50R 15
Bot of my current tyres are Front 185 60R 14's I assume that this was done in error by a previous owner & I just didn't realise the last time I changed the tyres, what do you think? And this may sound like a dumb question but will the two different sizes fit on the same rims?
Let me know what you think,
Cheers,
Pete
Pete JB
Re: Tyre Size Advice
Postby Steve » Mon, 15 Jun 2009 2:49 +0000
What year/model/spec is your car?
Postby Pete JB » Mon, 15 Jun 2009 3:18 +0000
It's a MK2 1999 1.8, guess I should have mentioned that. :oops:
Pete JB
Postby Pete JB » Mon, 15 Jun 2009 11:49 +0000
BUMP - no ideas folks? 19 views & only one answer! :D :D
Pete JB
Postby laur » Tue, 16 Jun 2009 9:27 +0000
Hi there,
It can be a mistake:
Front 185 60R 14
Rear 195 50R 15
In this case you need to different rim size- 14 on the front and 15 on the back.
PM your mail and I will send you a pdf about it.
Hope that will help you.
laur
Postby Pete JB » Tue, 16 Jun 2009 12:37 +0000
Right, I'm daft. The door car d mentions the two different tyre sizes, but does not specifically mean that there should be two different sizes, the text in the various boxes just seems to line up, I've attached a photo to show you what I mean. Silly me :oops: :oops: :oops: :oops:
Pete JB
Postby Midlifecrisis » Thu, 18 Jun 2009 11:18 +0000
Pete
I think what this is saying is that these are recommended tyre sizes - whichever ones you choose - but not mixing sizes front/rear. Regardless, the pressure is 26psi. Personally I prefer a slightly harder tyre pressure - around 28psi
Midlifecrisis
Return to General discussion
