The price of Coal !!!Waste oil heaters
Postby sidewaysreilly » Thu, 17 Dec 2009 11:46 +0000
Was up in Norn Iron this week and a lad on The Red Bay Crew sells Coal so i filled the van. 6 25 kg bags of coal and 3 of slack for £60. He threw a bag of logs in too.
Last edited by sidewaysreilly on Fri, 18 Dec 2009 12:44 +0000, edited 1 time in total.
Re: The price of Coal !!!
Postby leamyj » Thu, 17 Dec 2009 11:49 +0000
Not bad at all, I assume it was smokeless coal or are you outside of the area??
Don't have an open fire in my house as I put in a Gas one years ago, the way things are going I might just take it out again :)
Postby sidewaysreilly » Thu, 17 Dec 2009 11:51 +0000
no she was the good stuff, loads of smoke to annoy the gulls!!!
Postby CashelMX5 » Fri, 18 Dec 2009 12:07 +0000
You could also throw a few bags into the 5 heading south, they'd pay for a good weekend :lol:
Postby sidewaysreilly » Fri, 18 Dec 2009 12:12 +0000
deffo, the next time i'm up there i'll fill the vito. Was interesting going round roundabouts with all the weight out back tho, thank god for ebd or whatever it is called. Dunno what coal is down here, had enough from last year but want doul cosyness for Christmas.
Postby leamyj » Fri, 18 Dec 2009 12:15 +0000
All these heads of state in Copenhagen trying to sort out global warming, and here's you.................
:mrgreen: :mrgreen: :mrgreen:
Postby sidewaysreilly » Fri, 18 Dec 2009 12:18 +0000
wait till i perfect my waste oil burner Johnny, doul house will look like the Titanic flat out . :bom: :bom: :bom: :!: :!:
Postby leamyj » Fri, 18 Dec 2009 12:27 +0000
A mate of mine has developed one of them. He uses, in his workshop,a standard household burner unit attached to an old gas cylinder(You know the big red ones). A section of piping is attached and runs out through a hole in the wall and there's not a sign of black smoke from it at all. The secret, apparently, is to get the unit running on standard kerosene first and then gradually feed in the waste oil, a bit of a balancing act at first but once it's up to temperature..WOW, it glows red hot!! He's a mechanic and has no shortage of waste oil to put into the tank. Wisely, he has installed a cage around it because it would do some serious damage if you were to come into contact with it.
Postby sidewaysreilly » Fri, 18 Dec 2009 12:32 +0000
yeah thats the plan and ill use a coil around it and pass it thro a marine heat exchanger into the house system. Here is the one you are on about:
http://www.journeytoforever.org/biofuel ... h/me4.html
Postby leamyj » Fri, 18 Dec 2009 12:35 +0000
Cool, I'll pass that on to him, he might be able to make me one!!!!
Postby sidewaysreilly » Fri, 18 Dec 2009 12:40 +0000
you could do it yourself very easily and if i do start, ill make a few if people want them.It will be easier to make a few and quicker. If a few of us get our heads together to accuire the bits it will be easy. Just be nice to your local chippy for free oil.
Re: The price of Coal !!!Waste oil heaters
Postby CashelMX5 » Fri, 18 Dec 2009 1:28 +0000
And while your at it you could run up an ould poteen still :shaking2: :lol:
Postby sidewaysreilly » Fri, 18 Dec 2009 1:37 +0000
now yer talkin T :thumright: :thumright: :king: om....
Postby Steve » Fri, 18 Dec 2009 2:55 +0000
leamyj wrote:All these heads of state in Copenhagen trying to sort out global warming, and here's you.................
It was pointed out to them that the globe isn't warming any more.. so now they call it "Climate change".
Postby paulie1981 » Fri, 18 Dec 2009 10:02 +0000
sidewaysreilly wrote:wait till i perfect my waste oil burner Johnny, doul house will look like the Titanic flat out . :bom: :bom: :bom: :!: :!:
I think we should start a nomination for quote of the month or something to that effect: I nominate the above :D
paulie1981
Return to General discussion
