Page 1 of 2
The price of Coal !!!Waste oil heaters
Thu, 17 Dec 2009 11:46 +0000
by sidewaysreilly
Was up in Norn Iron this week and a lad on The Red Bay Crew sells Coal so i filled the van. 6 25 kg bags of coal and 3 of slack for £60. He threw a bag of logs in too.
Re: The price of Coal !!!
Thu, 17 Dec 2009 11:49 +0000
by leamyj
Not bad at all, I assume it was smokeless coal or are you outside of the area??
Don't have an open fire in my house as I put in a Gas one years ago, the way things are going I might just take it out again
Thu, 17 Dec 2009 11:51 +0000
by sidewaysreilly
no she was the good stuff, loads of smoke to annoy the gulls!!!
Fri, 18 Dec 2009 12:07 +0000
by CashelMX5
You could also throw a few bags into the 5 heading south, they'd pay for a good weekend
Fri, 18 Dec 2009 12:12 +0000
by sidewaysreilly
deffo, the next time i'm up there i'll fill the vito. Was interesting going round roundabouts with all the weight out back tho, thank god for ebd or whatever it is called. Dunno what coal is down here, had enough from last year but want doul cosyness for Christmas.
Fri, 18 Dec 2009 12:15 +0000
by leamyj
Fri, 18 Dec 2009 12:18 +0000
by sidewaysreilly
Fri, 18 Dec 2009 12:27 +0000
by leamyj
A mate of mine has developed one of them. He uses, in his workshop,a standard household burner unit attached to an old gas cylinder(You know the big red ones). A section of piping is attached and runs out through a hole in the wall and there's not a sign of black smoke from it at all. The secret, apparently, is to get the unit running on standard kerosene first and then gradually feed in the waste oil, a bit of a balancing act at first but once it's up to temperature..WOW, it glows red hot!! He's a mechanic and has no shortage of waste oil to put into the tank. Wisely, he has installed a cage around it because it would do some serious damage if you were to come into contact with it.
Fri, 18 Dec 2009 12:32 +0000
by sidewaysreilly
yeah thats the plan and ill use a coil around it and pass it thro a marine heat exchanger into the house system. Here is the one you are on about:
http://www.journeytoforever.org/biofuel ... h/me4.html
Fri, 18 Dec 2009 12:35 +0000
by leamyj
Cool, I'll pass that on to him, he might be able to make me one!!!!
Fri, 18 Dec 2009 12:40 +0000
by sidewaysreilly
you could do it yourself very easily and if i do start, ill make a few if people want them.It will be easier to make a few and quicker. If a few of us get our heads together to accuire the bits it will be easy. Just be nice to your local chippy for free oil.
Re: The price of Coal !!!Waste oil heaters
Fri, 18 Dec 2009 1:28 +0000
by CashelMX5
And while your at it you could run up an ould poteen still
Fri, 18 Dec 2009 1:37 +0000
by sidewaysreilly
Fri, 18 Dec 2009 2:55 +0000
It was pointed out to them that the globe isn't warming any more.. so now they call it "Climate change".
Fri, 18 Dec 2009 10:02 +0000
by paulie1981
I think we should start a nomination for quote of the month or something to that effect: I nominate the above
