i have a miss fire from about idle to 3000rpm on my 93 eunos
and from what i read it is most liklly the coil pack
does anyone have one i could try to see if it is the problem
need donegal helpi have a miss fire from about idle to 3000rpm on my 93 eunos
and from what i read it is most liklly the coil pack does anyone have one i could try to see if it is the problem
Re: need donegal helpWe have coil packs for sale and it is mostly that as common problem on mx5,s. 086 8226506.Is it running ok when cold and then gets worse as it warms up ??
Re: need donegal helphey autocheck it is always there warm or cold it just started out of the blue it was running grand then i stoped went into a shop came back out and took of and it was missing
Evan
Re: need donegal helpOnly seeing this now. I had a similar problem once after I changed a set of spark plugs. Turned out the leads were not making good contact with the new plugs (they were quite old). Put on a new set of leads and it was fine!
