Trip to Cork Friday afternoonI will be travelling to Cork Friday afternoon if anyone needs anything ,leaving Dublin 2pm ,leaving Cork 6pm.
Re: Trip to Cork Friday afternoonI need a few bits
Coolant Temp Sensor plug The two chrome plates that on the rear deck for where the frankenstein bolts go Battery Clamp Water pump belt Fixed antenna Could you meet me and Nico at my shed its just off the motorway You can drive my car if you want
Re: Trip to Cork Friday afternoonI'll be around as Rhys said
And I'd add to that: -If you have space for it, a PPF frame with diff mounting bolts, the ones going through my 1.6 diff seem quite seized, and I'd like to use your 1.8 torsen one day -A MK2 Master cylinder and brake Servo for non ABS car. Even if not the biggest one, one slightly bigger than the 1,6 would do? I will bring back the one for MK2 ABS you gave me last time anyway Nico
Re: Trip to Cork Friday afternoonHi no problem but is the belt the older V type belt on the alternator and I will check for NON ABS mk2 master cyl but we may not have.How many outlets are on it .3 ??
Re: Trip to Cork Friday afternoonYes it's an early car, didn't check if it goes to alternator too but you're probably right. And also yes, the non ABS MC has 3 outlets.
See you tomorrow! Nico
Re: Trip to Cork Friday afternoonIts the v type that wraps around the alternator
Re: Trip to Cork Friday afternoonRobert, did you apply for the Cork visa ??! You could be refused at the county bounds........
Re: Trip to Cork Friday afternoonAh the Cork people love me ,its just the language barrier I find hard......How u doin boy.!!
Re: Trip to Cork Friday afternoonWe can register you for a FETAC course in both Cork dialects: North side and South side. You'll be an honorary native
in no time - "D'ya know what I mean like, bhoy ?" 1992 Eunos Roadster BRG V-Spec 1.6
Re: Trip to Cork Friday afternoonThanks for delivering the parts Rob & Andrew
Nico
Re: Trip to Cork Friday afternoonThanks Nico and Rhys,great spin in the twin turbo,s.....Got home at 11pm but dirty ,wet night so had to slow down to 100km with trailer .I will send you invoice for the filming rights etc.
