cam belt
Postby willie » Wed, 19 Sep 2018 12:06 +0000
I want to change the cam belt and see several makes for sale out there, just wondering if there is a recommended make.. The car is 1990 but only 72K miles and i cant find any record of it being changed.
Also is there anything else i should change at the same time ? water pump ?etc
willie
willie
Re: cam belt
Postby 93 Mk1 » Wed, 19 Sep 2018 5:37 +0000
I find the Blue Print stuff for these cars to be pretty okay. The water pump should be looked at if you are doing the timing belt. A genuine Mazda cam cover gasket is recommended. And as you have the cam over off, it might be worth checking to see if the CAS seal is leaking.
93 Mk1
Re: cam belt
Postby willie » Wed, 19 Sep 2018 5:47 +0000
Thanks , Can I ask what the CAS is ?
willie
Re: cam belt
Postby 93 Mk1 » Thu, 20 Sep 2018 9:47 +0000
willie wrote:Thanks , Can I ask what the CAS is ?
It's the cam angle sensor. It has a rubber seal that is prone to leaking. It is quite easy to do, especially when removing the cam cover.
93 Mk1
Re: cam belt
Postby willie » Thu, 20 Sep 2018 8:46 +0000
Thanks once again.
willie
Re: cam belt
Postby Steve » Thu, 20 Sep 2018 10:46 +0000
Also, I think you mentioned your car is auto? If so, you may need a crank locking tool to hold it while you loosen/tighten the crank bolt.
This thread has a pic of one you can make near the end :
https://forum.miata.net/vb/showthread.php?t=554627
This is worth a watch (skip to 1min in)
Return to Engine Mods
