Re: Roadster Performance
Postby leamyj » Thu, 02 Jun 2011 1:50 +0000
MollyMX5 wrote:
Would anyone have the power steering pump for me?
Should be easy to get one...put up a post in the "Wanted" section.
Postby johnv » Thu, 02 Jun 2011 8:37 +0000
iv had issues with the power steering since the big freeze. it feels lumpy it only happens now and again im hopeing it will go away
johnv
Postby MollyMX5 » Thu, 02 Jun 2011 10:52 +0000
well my mechanic says it works but the fluid is not circulating properly if I understand correctly
MollyMX5
Postby leamyj » Thu, 02 Jun 2011 11:46 +0000
MollyMX5 wrote:well my mechanic says it works but the fluid is not circulating properly if I understand correctly
Finally found this thread again.
Molly, ask your mechanic to flush the old fluid and replace it before going the new pump route ( if not done already). I have one that I know was working perfectly before I removed it from my old mk1, contact me if you decide to go with a replacement. Yours for €50 plus P&P.
Postby MollyMX5 » Fri, 03 Jun 2011 1:05 +0000
thanks, will do and I'll be in touch.
MollyMX5
Return to Engine Mods
