Re: 1.8 flywheel in a 1.6
Postby ger » Tue, 30 Jul 2013 9:57 +0000
I Have an exedy stage 1 1.6 clutch, its the one thats 40% up rated with the damper, think they made a few different ones over the years. Holds 8psi (170hp) fine says its good for 200lbs of torque. Feels a fair bit stiffer than std but solid engagement and once you get used to the stiffer feel drives like stock.
Postby rhysmate » Wed, 31 Jul 2013 8:43 +0000
ger wrote:I Have an exedy stage 1 1.6 clutch, its the one thats 40% up rated with the damper, think they made a few different ones over the years. Holds 8psi (170hp) fine says its good for 200lbs of torque. Feels a fair bit stiffer than std but solid engagement and once you get used to the stiffer feel drives like stock.
Myself and Nico went to Robert and got my flywheel (1.8) and i have an exedy clutch will be here this week :)
Cheers for all the advice lads ill update this thread will a verdict in the coming weeks/months
Return to Engine Mods
