Re: Supercharger info
Postby 4ag-kp » Thu, 24 Oct 2013 5:23 +0000
That would be great Andrew. No didnt touch it yet i have the sc i need to gather the rest of the bits first and make a loom for the omex. probably need injectors an bigger fuel pump as well.
4ag-kp
Postby andrew » Thu, 24 Oct 2013 8:20 +0000
You don't need to touch the fuel pump, injectors yes. I recommend EV14'S you will get them on ebay from the states or possibly mx5nutz. Fair play to you wiring the loom.
andrew
Postby rhysmate » Fri, 25 Oct 2013 11:33 +0000
Get us some pics! :D
Postby 4ag-kp » Fri, 25 Oct 2013 6:18 +0000
rhysmate wrote:Get us some pics! :D
Ive tried an failed miserably :?
4ag-kp
Postby 4ag-kp » Fri, 25 Oct 2013 6:37 +0000
andrew wrote:You don't need to touch the fuel pump, injectors yes. I recommend EV14'S you will get them on ebay from the states or possibly mx5nutz. Fair play to you wiring the loom.
Are the just an after market injector or mazda ones. Ya id tacle anything the omex came with a loom but its off an old ford pinto or something that had throttle bodies so i'll just have to mess about with the plugs an get a trigger wheel. Did you charge a 1.6 or 1.8
4ag-kp
Postby 4ag-kp » Fri, 25 Oct 2013 7:13 +0000
4ag-kp
Postby andrew » Sat, 26 Oct 2013 1:05 +0000
These lads, I got 550cc versions. The only use about 55-60 Duty cycle to make my AFR's, compared to the 1.8 injectors I was using these were pulling 100% duty cycle. Not much room for error. They also idle very well.
http://www.ebay.ie/itm/4-EV14-Fuel-Inje ... 5649ce9e5d
Car looks great, silver hardtop looks well on white.
andrew
Postby 4ag-kp » Sat, 26 Oct 2013 2:10 +0000
Cheers Andrew the hard top is now white tho
Those little buggers are expensive has any one used rx7 ones or would they even work.
4ag-kp
Postby andrew » Sat, 26 Oct 2013 2:26 +0000
You will need to check if your ecu will work with whatever injectors you chose. Rx7 ones are not reputed to be good, rx8 are ok but these and id1000's are supposed to be the best. The flow matching of the injectors is important for good idle and even fuel flow to all cylinders. Buy cheap, buy twice.
andrew
Postby Steve » Sun, 27 Oct 2013 4:24 +0000
worth checking out RC Engineering too, I'm using their 440cc version of these :
http://www.forcedinductionsonline.com/i ... uct_id=955
Postby 4ag-kp » Sun, 27 Oct 2013 4:36 +0000
Thats more like it steve budget build ftw
4ag-kp
Postby Steve » Sun, 27 Oct 2013 4:39 +0000
emmm... that price is "each" I'm afraid
Postby 4ag-kp » Sun, 27 Oct 2013 4:48 +0000
ha ooops missed that part :oops: Has any one on here made there own mounting brackets for the sc or is it just as well to get them off Tim lane
4ag-kp
Postby andrew » Mon, 28 Oct 2013 8:10 +0000
I would buy the mounting kit from Tim, saves a lot of hassle.
andrew
Postby rhysmate » Tue, 29 Oct 2013 10:10 +0000
Met Rob over the weekend at WGH drift day.. Good to meet ya dude
Emergency hairdressing on the way ;) haha
Return to Engine Mods
