Low coolant
Fri, 16 Apr 2010 8:02 +0000
by jaybond
Hi folks, I'm coming out of hibernation.
When I fill my radiator it seems to loose fluid but not over heat. When it cools down there is a lot of room for more fluid. It seems to disappear only after it gets fully warmed up. It never appears to over heat. Any thoughts?
Re: Low coolant
Fri, 16 Apr 2010 10:07 +0000
by Paschal
jaybond wrote:Hi folks, I'm coming out of hibernation.
Hi Jaybond. Did you not have a problem at the Japfest day last year. Is your current problem related?
Re: Low coolant
Sat, 17 Apr 2010 10:25 +0000
by jaybond
I don't think so. The problem at Japfest was a hose that had worn a sprung a leak. I replaced it and flushed the rad and refilled and then since then I have had my eye on the fluid and that is why I noticed.
Is there any trick in filling it up maybe?
Re: Low coolant
Sat, 17 Apr 2010 12:21 +0000
Rad cap maybe? Sounds like its leaking only under pressure.. worth trying first.
Could be a pin hole leak somewhere too thats drying out with the heat of the engine. You can use UV dye and a blacklight to trace it.
Re: Low coolant
Mon, 10 May 2010 11:26 +0000
by charged_rs
check your cooling fan is working ,
let car heat up to normal temp and see if it kicks in
if not , ground the tfa plug in the diagnostics connector , if it works you have a bad thermoswitch
i reckon your coolant is boiling off
