How To Hook Up Vacum Pipes With Turbo Setup
Postby haydn itr » Thu, 24 May 2012 12:52 +0000
hey lads need some help on finishing up the last few bits. need to know what pipes go where . heres the images off whats left to be connected up
haydn itr
Re: How To Hook Up Vacum Pipes With Turbo Setup
Postby Steve » Thu, 24 May 2012 1:10 +0000
That black box looks like a Manual Boost Controller. If so, it should hook up to the turbo vac outlet on one end and the wastegate can on the other. Any indication on it as to which is which?
Postby Steve » Thu, 24 May 2012 1:25 +0000
It looks like its one of these :
http://airinc.thomasnet.com/item/air-va ... /310-12vdc?
Also, http://www.boostvalve.com/motorsport.html seem to sell a similar one
Might be worth firing them a photo via email and see.
Postby haydn itr » Thu, 24 May 2012 6:24 +0000
Ye it's a boost solenoid alryt just don't know where I have to run the vacuum from into it
haydn itr
Postby rhysmate » Mon, 28 May 2012 9:46 +0000
haydn itr wrote:Ye it's a boost solenoid alryt just don't know where I have to run the vacuum from into it
the solenoid needs to be inline with the boost signal to the actuator.. its a valve that fools the actuator into thinking theres less boost so it opens at a higher boost? thought it needed to be directly from the turbo outlet??
like this
you can put the controller inline with the black hose then
Postby Fergus » Thu, 07 Jun 2012 11:48 +0000
Is that a BOV in the 3rd picture ?
In the last picture, why do you have a fuel line connected up to the intake manifold ?
That port is suppose to be connected directly to the Cam cover next to it via a PCV Valve http://www.mx5parts.co.uk/valve-mazda-mk1225-p-783.html
Postby Fergus » Fri, 08 Jun 2012 12:01 +0000
EBC setup...
Best leave your EBC where it is as it's already wired up and just run longer lines to the turbos wastegate and actuator, less heat where it is located right now.
Return to Engine Mods
