Supercharger info
Postby 4ag-kp » Mon, 07 Oct 2013 8:10 +0000
Hey guys im thinking of getting an Eaton M45 sc for my mk2. I have an Omex 600 ecu but not sure if it will run a sc i presume it will working off a map sensor.
Still unsure on a few things like injectors what are lads using. Also found this so sent them an email http://www.trlanefabs.co.uk/SUPERCHARGER-PARTS.html
4ag-kp
Re: Supercharger info
Postby Steve » Tue, 08 Oct 2013 1:01 +0000
wow, impressive looking ECU! Anti-lag + Traction control, nice. Yep it looks like a map sensor is an option.
http://omextechnology.co.uk/page75.html
Injectors.. depends what kind of power/boost you'll be aiming for?
Postby 4ag-kp » Tue, 08 Oct 2013 6:55 +0000
I picked it up ages ago of some rally lad in Kerry i had intended to use it on a 20v toyota but i went for a bigger engine instead. What i have is a mk2 1.8 rs and waiting on an Eaton M45 from England. What would be safe power on these engines for a daily driver an some track time
4ag-kp
Postby Steve » Tue, 08 Oct 2013 10:41 +0000
this guy :
http://trackdogracing.com/info/dyno/99_M45_8PSI.pdf
Has this spec :
Car/System: '99 Miata M45 w/ TDR Intercooler
Max. Power: 196.46 RWHP
Max Torque: 173.00 LB/ft
Stock M45 supercharger with TDR Intercooler
JR PowerCard with Walbro fuel pump
150 mm Crank Overlay pulley and 62.5mm SC pulley, 8PSI
Stock motor with JRSC header
TDR Air Filter Kit
TDR Heat Shield
Goodwin Mid-pipe and Racing Beat muffler
and prob about 440cc injectors.
The engine is good for 250-ish but long term daily... I'd aim for 225-max
Postby 4ag-kp » Wed, 09 Oct 2013 7:12 +0000
Cheers Steve i think i have a lot of reading to do about all this supercharger craic. Can you recommend any one in Ireland that maps mx's an knows the score wit supercharger ones.
4ag-kp
Postby Steve » Wed, 09 Oct 2013 9:16 +0000
have you already ordered the supercharger?
Postby leamyj » Thu, 10 Oct 2013 1:56 +0000
Chap on here called Andrew may be of help..
Postby 4ag-kp » Thu, 10 Oct 2013 6:33 +0000
Ya Steve shes on the way from the uk hopefully have it early next week.
Cheers Leamyj Does that guy do a bit of mapping?
4ag-kp
Postby leamyj » Fri, 11 Oct 2013 8:00 +0000
Dunno, but if you check him out on the members list at the top of the page and PM him, you might get your answer :wink:
Postby 4ag-kp » Wed, 16 Oct 2013 6:26 +0000
The supercharger has landed. Time to go make some brackets now..
4ag-kp
Postby Steve » Thu, 17 Oct 2013 2:52 +0000
cool, will be interested to see your progress
Postby 4ag-kp » Thu, 17 Oct 2013 6:37 +0000
I was reading a thread there last night wont say where :oops: but the lad had cad drawings for the mounting brackets an little bits and pieces so i emailed him hopefully hey will send them on an i can get the ball rolling.
Need to get a 1.6 throttle body an a bypass valve
Any one on here using the ebay exhaust manifold the seem 2 cheap to be any good
4ag-kp
Postby andrew » Tue, 22 Oct 2013 4:08 +0000
Hi,
I have a mini charger on my 1.6, dyno gave 199bhp and 175ft/lbs. I have a megasquirt ecu and 550cc EV14's. Its loud and great fun. I have build thread on here.
andrew
Postby 4ag-kp » Tue, 22 Oct 2013 6:28 +0000
andrew wrote:Hi,
Cheers Andrew i will have a look for that. Some figures for a 1.6 fair play to ya. Are you using that as a daily driver.
4ag-kp
Postby andrew » Tue, 22 Oct 2013 7:29 +0000
No, it's road legal but it's become more track focused. I might be able to help you mapping it if your near leixlip. Have you put the ecu in yet
andrew
Return to Engine Mods
