Emanage blue problems need help
Postby taitt » Sat, 09 Aug 2014 12:00 +0000
i used miata wiring diagram because it all i could find
im getting error code 11 (incorrect wiring or disconnected airflow signal1)
this only happens on idle if i start car and keep small rev on it works perfect
any thoughts would be really helpful
thanks evan
taitt
Re: Emanage blue problems need help
Postby Steve » Mon, 11 Aug 2014 10:12 +0000
I presume you have double-checked your signal wire + airflow-input/airflow-output wires? (white wire and green wire I think).
Yours is a '93 1.6 right? If it is, I think you need to set JP9 to open (increases in value), for a 1.8/mk2 set it to 1-2 (decreases)
Some wiring diagrams here : http://www.miataforumz.com/miata-wiring.php
Return to Engine Mods
