Need a map (Jul/Aug 2015)
Postby Asmooh » Tue, 24 Mar 2015 1:37 +0000
Hello,
I was wondering if anyone knows a good private person or company that can make a map for me, megasquirt PnP for the 1.6 NA
Mods will be:
- 16G turbo
- 850cc injectors
- No AFM
- Catback
and in Oct/Nov I need a re-tune because of the 264 degrees HKS cams
Asmooh
Re: Need a map (Jul/Aug 2015)
Postby andrew » Fri, 03 Apr 2015 7:55 +0000
Try Joe Power, chipped IRE 0879113843
I would bring a base spark and fuel target map with you if you had one before installing the cams, it will reduce the cost for you
andrew
Postby Asmooh » Sun, 12 Apr 2015 5:31 +0000
andrew wrote:Try Joe Power, chipped IRE 0879113843
i tried they dont reply on email
Asmooh
Postby Randy » Mon, 13 Apr 2015 1:30 +0000
Jayyyysus, 850c injectors? lol..
Whereabouts are you located? There is a fella called Aonghus in Galway who is suppose to be a wizard with MS ecu's. I'll be going to him myself sometime later this year when I get a new boost controller.
Randy
Postby Steve » Mon, 13 Apr 2015 3:35 +0000
any details on that guy in Galway?
Postby Randy » Mon, 13 Apr 2015 6:29 +0000
He has a full rolling road and all, and use to work for another company in Dublin, unsure of what they're called.
Think his number is 086-332-3980. Aonghus is his name.
Randy
Postby sti-mx5 » Mon, 13 Apr 2015 6:40 +0000
Think it was couture auto he worked for and he bought the rolling road off them and set it up in Galway.
sti-mx5
Postby Randy » Mon, 13 Apr 2015 7:10 +0000
sti-mx5 wrote:Think it was couture auto he worked for and he bought the rolling road off them and set it up in Galway.
You're 100% correct, man. Couldn't remember the name of the company.
Randy
Postby Steve » Tue, 14 Apr 2015 9:20 +0000
nice one, will look him up, thanks.
Postby Asmooh » Sun, 19 Apr 2015 12:45 +0000
Randy wrote:Jayyyysus, 850c injectors? lol..
Located both in Holland or Leixlip :) the car is atm still in Holland
Asmooh
Postby Randy » Mon, 20 Apr 2015 12:44 +0000
What power are you going for, and what other support are you running for the build? I thought I was going a bit overboard with 660cc injectors. :P
Randy
Postby Asmooh » Mon, 27 Apr 2015 9:19 +0000
Randy wrote:What power are you going for, and what other support are you running for the build? I thought I was going a bit overboard with 660cc injectors. :P
I'm aiming at 400whp :)
Asmooh
Postby Randy » Mon, 27 Apr 2015 12:59 +0000
Crazy power, man. Thought I was doing well to get 237. :P
What supporting mods are you doing? Internal work I'd imagine?
Randy
Postby Asmooh » Mon, 27 Apr 2015 3:28 +0000
Randy wrote:Crazy power, man. Thought I was doing well to get 237. :P
Well, I have 2 stages of this project, 1 is stock power with no internal mods (200whp)
and a full forged engine rebuild including LSD diff and more (400whp)
and ofc chassic reforged and bars and all kinds or useless things to make it stiffer and hold the power
Will be a daily btw ;)
Asmooh
Postby Randy » Mon, 27 Apr 2015 3:45 +0000
Do a build thread man in the project section. Would love to see how you get on with it.
Randy
Return to Engine Mods
