Bee*R not working
Postby emarkey » Sat, 11 Apr 2015 5:10 +0000
Guys, I have just put in a Bee*R rev limiter into my (auto to manual swapped) 1994 1.8l eunos mk1. I have connected the wires as instructed by bee*r and numerous people online and it isnt working correctly.
If i have the Bee*r set to 4k revs and floor it, it will rev to 4k, cut some ignitions, then rev past 4k, then back to 4k, cut some ignitions again, and so on in that fashion. If working correctly it should rev to 4k and stay there making awesome happen.
Any ideas? Perhaps my bee*r is faulty.
emarkey
Re: Bee*R not working
Postby scallan » Sat, 11 Apr 2015 9:47 +0000
I dont know much about them but have heard of them causing awful engine problems on nissans and toyotas.
scallan
Postby Steve » Sun, 12 Apr 2015 7:13 +0000
Is that not how its supposed to work when its working as a 2 step rev limiter?
like this :
https://www.youtube.com/watch?v=sEz4dPZH1fc
Postby emarkey » Mon, 13 Apr 2015 8:45 +0000
It supposed to work like in that video, but that's not what's happening at all. I will try get a video up.
emarkey
Postby Steve » Mon, 13 Apr 2015 12:06 +0000
also, which wires did you use for RPM and ignition?
Postby emarkey » Tue, 14 Apr 2015 12:59 +0000
Steve wrote:also, which wires did you use for RPM and ignition?
Rpm - Crank sensor
ignition - Cam sensor.
I installed one in my mates skyline and it worked fine, so Ill try mine on his skyline to see if my bee*r in actually broken.
emarkey
Return to Engine Mods
