Throttle bodies and Megasquirt
Postby MX5Spares » Fri, 07 Apr 2017 7:49 +0000
Just purchased set throttle bodies and DanSt inlet manifold PLUS megasquirt 2 for my Mk1 .Over 1500 pounds NEW. I will post pics when I have them fitted
Re: Throttle bodies and Megasquirt
Postby andrew » Fri, 07 Apr 2017 9:11 +0000
Mmmm, that will sound good.
andrew
Postby MX5Spares » Sat, 08 Apr 2017 7:04 +0000
Hopefully but I have VVT engine in my mk1 1.8 so will need to check out either "locking" the vvt or fit non vvt head .No too bad either way and if I fit non vvt head I might get it uprated a bit
Postby Steve » Sun, 09 Apr 2017 5:44 +0000
Oh jebus... will sound fantastic. Who did you buy the ecu from?
Postby MX5Spares » Mon, 10 Apr 2017 8:20 +0000
got it on ebay , a chap in england was doing a turbo conversion and was doing away with the carbs as he wanted more power
Postby MX5Spares » Wed, 19 Apr 2017 7:15 +0000
Any "experts" that can assist with fitting/setting up etc
Postby andrew » Wed, 19 Apr 2017 9:13 +0000
I'll give you a hand with the ecu if you need it.
andrew
Postby MX5Spares » Thu, 20 Apr 2017 6:39 +0000
Hi Andrew ,thanks.I will give you a shout nearer the time.Its Megasquirt 2 but not sure my connectors will fit straight in to it?
Return to Engine Mods
