cam belt
Postby willie » Wed, 19 Sep 2018 12:06 +0000
I want to change the cam belt and see several makes for sale out there, just wondering if there is a recommended make.. The car is 1990 but only 72K miles and i cant find any record of it being changed.
Also is there anything else i should change at the same time ? water pump ?etc
willie
willie
Re: cam belt
Postby 93 Mk1 » Wed, 19 Sep 2018 5:37 +0000
I find the Blue Print stuff for these cars to be pretty okay. The water pump should be looked at if you are doing the timing belt. A genuine Mazda cam cover gasket is recommended. And as you have the cam over off, it might be worth checking to see if the CAS seal is leaking.
Re: cam belt
Postby willie » Wed, 19 Sep 2018 5:47 +0000
Thanks , Can I ask what the CAS is ?
willie
Re: cam belt
Postby 93 Mk1 » Thu, 20 Sep 2018 9:47 +0000
willie wrote:Thanks , Can I ask what the CAS is ?
It's the cam angle sensor. It has a rubber seal that is prone to leaking. It is quite easy to do, especially when removing the cam cover.
Re: cam belt
Postby willie » Thu, 20 Sep 2018 8:46 +0000
Thanks once again.
willie
Re: cam belt
Postby Steve » Thu, 20 Sep 2018 10:46 +0000
Also, I think you mentioned your car is auto? If so, you may need a crank locking tool to hold it while you loosen/tighten the crank bolt.
This thread has a pic of one you can make near the end :
https://forum.miata.net/vb/showthread.php?t=554627
This is worth a watch (skip to 1min in)
Return to Engine Mods
