Engine running rich
Recommend a garage in which you've had good experiences. Please date when last used(ish) and the work done. No "Name and shame" please.
Engine running rich
Postby Aerofoil » Fri, 27 Oct 2017 10:51 +0000
Can anybody recommend a trustworthy garage that can repair the engine on my mk2.5 2004. It won't tick over properly and the last mechanic ripped me off and never made any progress.
I would be grateful for any recommendations.
Aerofoil
Re: Engine running rich
Postby Steve » Tue, 31 Oct 2017 1:41 +0000
Where are you based?
Postby MX5Spares » Tue, 31 Oct 2017 5:34 +0000
Try the temperature sensor at back of engine.They are known causes of issues and especially running rich
Postby Aerofoil » Tue, 07 Nov 2017 12:09 +0000
Hi Steve. I live in Roscommon, about 10 miles north of the town on the N61 Boyle road..
Aerofoil
Postby Steve » Tue, 07 Nov 2017 12:10 +0000
As Robert said above, rear temp sensor (then check O2 sensor and the air intake for leaks post-MAF).
Postby Pops » Tue, 07 Nov 2017 6:18 +0000
It may help if you were to say when the problem started and to list in order all the work done and what results you got.
You said that the valve stem oil seals were done, did you have the current problems ( poor tick over, running rich etc) before getting the seals done or after as they shouldn’t affect idle etc
Postby Pops » Wed, 08 Nov 2017 3:31 +0000
List your faults, from first to last, what work have you had done to try to rectify the fault found s, from first to last and when( valve seals?????etc), and the result achieved.https://youtu.be/wR2f-q4WPfs
You most likely will get some good advice here but not if you don’t give all details
Return to Garage Recommendations
