rota zero plus
Re: rota zero plus
Postby fabfiveferg » Tue, 23 Feb 2010 11:38 +0000
ger wrote:What are your brake calipers and discs like, cause you will really see them after getting those wheels. Wont be long before you are looking at these
Mmmmmmm Fancy
Re: rota zero plus
Postby Stig » Tue, 23 Feb 2010 1:55 +0000
Mmmmmmm Fancy
+1
Re: rota zero plus
Postby mx5lude » Tue, 23 Feb 2010 3:35 +0000
nice :roll:
mx5lude
Re: rota zero plus
Postby adamaca » Sun, 28 Feb 2010 1:45 +0000
A friend has something very similar there rota something or other lovely wheels, but they used do rub the arches particularly at the back when cornering hard or pothole etc. he just put some adjustable ohlins on and the problem was solved.
They didnt go through the nct though, apparently your wheels are not aloud to extend past the bodywork. How does a caterham pass I wonder?
adamaca
Re: rota zero plus
Postby Ivan » Sun, 28 Feb 2010 10:00 +0000
adamaca wrote:A friend has something very similar there rota something or other lovely wheels, but they used do rub the arches particularly at the back when cornering hard or pothole etc. he just put some adjustable ohlins on and the problem was solved.
It passes because the wheels don't extend beyond the bodywork. They have mudguards.
Re: rota zero plus
Postby mx5lude » Sun, 28 Feb 2010 5:22 +0000
not a problem , spare wheels for mot, if they scrape a bit ill get the arches slightly rolled..
mx5lude
Re: rota zero plus
Postby AMMendes » Mon, 01 Mar 2010 6:00 +0000
With that offset you'll most probably going to need to rool fender.
Some friends have the drag DR-20 Et10 and it rub on the arches.
AMMendes
