Fitted a CAT bypass pipe yesterday amd wondering what to do with the sensor wire????????
Re: Cat by pass/ sensor wires......
Posted: Thu, 15 Apr 2010 3:07 +0000
by franksm
The after-cat sensor ? Remove the sensor and tape the wires up away from harm, it's not needed any more.
Posted: Thu, 15 Apr 2010 3:41 +0000
by sidewaysreilly
Thanks Frank, was wondering what that sensor is for if its not needed???
Posted: Thu, 15 Apr 2010 3:45 +0000
by franksm
It's like a fuse - when the cat overheats, the sensor melts and that causes a lamp to light up on the dash. Removing the sensor leaves the circuit open, and light extinguished. It's just a lamp too, not connected to the ECU (on MK1s)
Posted: Thu, 15 Apr 2010 4:19 +0000
Hmm.. so what could the spare wiring + lamp be used for.. ? Low fuel, fog light, "lights on", alarm warning light, knock sensor.. ?
Hmm.. wonder if you could get the alarm warning led in there..
