Painting CalipersI painted the Calipers on the car using Halfords red caliper brush on paint. I went for the brush on as it meant that the calipers didnt have to come off the car. Mask off / protect any hoses or leads etc. Using a mains drill with wire brush clean the caliper. Use sand paper to finish off. Use a brush to remove any dirt / dust remaining. Apply first coat and alloy to dry, approx 40mins. I gave mine 5 coats. Use gloves and cheap brushs as you wont be reusing these ones again. Its an easy job, takes a few hours and is cheap, paint is 15euro for 250ml but you will have lots left over. Well worth doing and mine turned out great.
You do not have the required permissions to view the files attached to this post. We are only immortal for a limited time
Re: Painting CalipersNice work!
I'm planning to do the same in my MX5 Mk 3. ![]() I'll made some pictures when I made it. ![]() www.mx5spain.com
