Reverse parking sensor
Postby goseatonio » Sun, 04 Mar 2012 3:09 +0000
As a daily driver and living in a crouded area, I'm planning to install a kit of reverse parking sensors in the rear bumper of my MX-5 NC.
Has anbody here installed them?
Any suggestion? :roll:
Thank you!
www.mx5spain.com
goseatonio
Re: Reverse parking sensor
Postby franksm » Wed, 07 Mar 2012 5:43 +0000
You can get a generic kit fitted to the '5 very easily. It just connects to the wire for the reversing lamps and to an earth. Hide the unit's brain in the tunnel over the wheelarch behind the panel in the boot.
This is the procedure on an XK8, but it'll be the same for any car:
Image Image Image
Postby goseatonio » Wed, 07 Mar 2012 10:53 +0000
Thank you franksm!
I'm planning to do in some weeks, and I'll take some shots in case they could help to anyone who can be interested.
www.mx5spain.com
goseatonio
Postby twail » Wed, 14 Mar 2012 7:07 +0000
I can get it done for you, 290, supplied, painted And fitted.
I'm in a nissan main dealer in bray.
We done a few of them a week.
Call 2720011 and ask for Tim if interested!!
twail
Postby leamyj » Wed, 14 Mar 2012 8:24 +0000
Eh?? You do know that he is in Spain :mrgreen:
Postby twail » Sat, 17 Mar 2012 12:03 +0000
Ohhh, there goes my commission!!
twail
Postby goseatonio » Sun, 18 Mar 2012 5:40 +0000
twail wrote:I can get it done for you, 290, supplied, painted And fitted.
Thank you, can you made it in my garage? :wink:
To be honest, I want to do by myself, I like DIY. :roll:
www.mx5spain.com
goseatonio
Postby kieran » Sun, 18 Mar 2012 7:47 +0000
add on dunedeal today 150 fitt :roll: :wink: ed
kieran
Postby goseatonio » Mon, 19 Mar 2012 5:56 +0000
Help!
I've just bought the Valeon beep&park kit n1, but the installation instructions supplied in the bok had a bad surprise:
Before purchasing, I readed the instructions in the Valeo official site, and in this "old" instructions, the connections between the kit and the car, were only two, and both the rear light.
But in the instrucions provided in the kit box, there is a third connection, it's a pink cable that should be connected at the bottom of the wheel to the +ACC connection.
Right now I'm not sure that this connection is a must, because in the web instructions, this connection is only for high level kits, with a screen (mine is really basic, with only sensors and a "beep") so I guess this connection is only neccesary if I decide to upgrade the kit (this is teorically possible) adding a screen.
But if this connection is a must, can you help me to find the +ACC point to connect, please?
Thank you in advance!!!!
So I would be gratefull if you could help me to find this +ACC connection
www.mx5spain.com
goseatonio
Postby franksm » Mon, 19 Mar 2012 10:04 +0000
Do you have daytime-running-lights ? If so, you could pick up a feed off one of the marker lamps in the bumper.
Failing that, though, your rear-window demister relay has a pink wire that will provide ACC (or IGN +ve). Doesn't matter if you have the relay fitted or not, the pink wire will be there in the loom in the boot area.
HTH
Postby goseatonio » Mon, 19 Mar 2012 10:53 +0000
Thank you franksm!
I'll try to install it in two weeks and I'll come back with the feedback and some shots (if I manage to make it work) :?
www.mx5spain.com
goseatonio
Postby leamyj » Tue, 20 Mar 2012 8:46 +0000
franksm wrote:Do you have daytime-running-lights ? If so, you could pick up a feed off one of the marker lamps in the bumper.
HTH
Frank, his car is a mk3...will the same wiring be there??
Postby goseatonio » Tue, 20 Mar 2012 7:14 +0000
Any pink cable could work for the connection? :roll:
www.mx5spain.com
goseatonio
Postby franksm » Tue, 20 Mar 2012 7:41 +0000
There should be four wires in that connector, but only one pink.
There's a green/black wire (+12V permanent), and there are two then that go to the window: a black/red wire and a grey wire.
These colours are from an American 2006 car.
What wires do you have in that loom ? If yours are different, you'll need to put a multimeter (or a 12V LED) onto the connection to test it.
Postby goseatonio » Tue, 20 Mar 2012 9:33 +0000
I'll check tomorrow the cables my NC has in the rear window. :shock:
www.mx5spain.com
goseatonio
