Mystery plug
Mystery plug
Postby MichaelM » Tue, 20 Aug 2013 9:43 +0000
Woohoo, first post, etc.
Hello all,
I'm currently working on my first MX5 and getting it on the road before the summers over hopefully.
When I jacked it up for the first time this friendly little fella was hanging down all by it's lonesome. I figure some folks around here might be able to shed some light on what it could be. I could not see anything else around there with an inspection mirror and when I hooked up a multiplier to it and played around the light switches it would only read 8 volts.
It does require an external rear fog light to be re-installed (it was not on the car but was supplied) but the connectors do not match up and the switch did not change the voltage.
In-case it matters, it's a 1990 V-Special Eunos Roadster 1.6
Cheers.
MichaelM
Re: Mystery plug
Postby Steve » Tue, 20 Aug 2013 11:04 +0000
am not 100% sure from the angle but it looks like its the cat sensor that Eunos models had. When the cat went the sensor would trigger a light to come on in the gauge panel "heat" (bottom left of the 4 in the middle).
I've no cat so have cable tied it up out of the way.
Welcome to the forum.
Re: Mystery plug
Postby sidewaysreilly » Tue, 20 Aug 2013 11:24 +0000
Yeah i'd agree. You dont need it.
Re: Mystery plug
Postby rhysmate » Wed, 21 Aug 2013 12:07 +0000
I'm the same. I've mine cut off and insulated
Re: Mystery plug
Postby MichaelM » Wed, 21 Aug 2013 6:38 +0000
Great. One less thing to worry about :D
Cheers.
MichaelM
