Light Problem MK 1
PostPosted: Sun, 23 Mar 2014 9:21 +0000
by gasha
Hi all I was driving today with my lights up with no lights switched on and the drivers side light started to go up and down on its own accord, I flicked the switch to put them down and the drivers light still went up and down on its own, I turned the engine off and no good, I got out and disconnected the battery, reconnected the battery and the light stopped flicking up and down in the closed position. If I had a bad connection at the switch surely I would have both lights going up and down.
Anybody come across this problem before?
Re: Light Problem MK 1
PostPosted: Sun, 23 Mar 2014 9:28 +0000
Spray a bit of wd 40 in the headlight motor connectors, prob have water in there.
Also, check your grounds under the washer bottle.
PostPosted: Sun, 06 Apr 2014 6:14 +0000
by MX5Spares
In order for to pop up and down it must be getting power supply from somewhere ,ie switch maybe??
