us lights on mk1 eunos
Postby emmet.harten3 » Thu, 12 Jun 2014 10:49 +0000
hi i was wondering about us lights on a jap import mk1 eunos they keep you turn signals turned on and some people put them in side reflectors i think they look kinda cool...
anyone no the name of the kit or done this before?
Last edited by emmet.harten3 on Thu, 12 Jun 2014 2:20 +0000, edited 1 time in total.
emmet.harten3
Re: us lights on mk1 eunos
Postby 93 Mk1 » Thu, 12 Jun 2014 11:24 +0000
These are not turn signals but actual driving lights in the US. You can wire the standard items (as they can be fitted with 5W bulbs) to your side lights so when the side
lights are switched on then the amber driving lights come on too.
Postby emmet.harten3 » Thu, 12 Jun 2014 2:36 +0000
oright so it a actual light i didt no that now... my mx5 there blank just a reflector..
was think of wire up a light to it and drill hole
i front indictator on last pic i put up has the kit on them
emmet.harten3
Postby Steve » Thu, 12 Jun 2014 2:57 +0000
to get the indicators to light up and then flashing when you indicate, you can buy the front lamp loom from a Canadian spec Miata (not positive the US loom is the same) and plug it into your eunos. It has a socket for a dual filament bulb, one used for each function.
If you take out the bumper reflector you might have the type that has a blanked off socket where you could fit a bulb.
Postby emmet.harten3 » Sun, 15 Jun 2014 10:28 +0000
thanks steve...
my reflecter are blank nothing there would have to drill a hole
emmet.harten3
