Painters.
Painters.
Postby Real Rayzor » Wed, 11 May 2016 12:04 +0000
Hi All...
Can anyone recommend car painters in the Clare area. I'm looking to get quotes for a full respray so I know what I'm in for.
I got one estimated quote today for €2000 minimum. Seems very high to me but I've no clue. Anyone had a full respray done and what kind of money approx.
Ray
Real Rayzor
Re: Painters.
Postby Steve » Wed, 11 May 2016 4:16 +0000
just sent you a pm Ray
Re: Painters.
Postby davith501 » Wed, 11 May 2016 4:40 +0000
I would expect that for a good prep and quality job. You could cut down by doing prep yourself as that's what most time consuming and most important job. Have you considered wrapping? Generally half the price, looks and wears well. Maybe could be an option..
Icon
RS
Mk1
davith501
Re: Painters.
Postby MX5Spares » Wed, 11 May 2016 5:09 +0000
1500/1700 average if you strip all the bits off it ,ie trims, door handles,lamps, bumpers etc
Re: Painters.
Postby Real Rayzor » Wed, 11 May 2016 7:27 +0000
I was thinking to just let the professionals to do all of it because I want this car looking the best it can, but now I'm thinking I should do the prep work myself to try and bring down the price.
Real Rayzor
Re: Painters.
Postby Real Rayzor » Wed, 11 May 2016 7:29 +0000
davith501 wrote:I would expect that for a good prep and quality job. You could cut down by doing prep yourself as that's what most time consuming and most important job. Have you considered wrapping? Generally half the price, looks and wears well. Maybe could be an option..
Hi Deivis,
Do you know of any companies that do it in the munster area. I'd certainly look into it.
Real Rayzor
Re: Painters.
Postby davith501 » Wed, 11 May 2016 7:44 +0000
Know few Polish lads that do some work. I'll call into their place and see what's the story. Will get back to you.
Icon
RS
Mk1
davith501
Re: Painters.
Postby Real Rayzor » Thu, 12 May 2016 12:01 +0000
Thanks a lot Deivis
Real Rayzor
Re: Painters.
Postby davith501 » Fri, 13 May 2016 12:30 +0000
You've pm.
Icon
RS
Mk1
davith501
Re: Painters.
Postby Fla » Tue, 17 May 2016 8:45 +0000
I'm having to do the same. Got similar 2k quote in Kerry but should be a lot less once I remove all plastics, trims rubbers etc. I'd like to think €1500 would be fair for a respray with good lacquer. I mean the car is tiny and has no roof..!!
Fla
---I'm back----
Fla
Re: Painters.
Postby Merlot man » Mon, 23 May 2016 6:14 +0000
I'd give Canavan here outside Lahinch a shout easy to deal with and a good painter .
To save money I'd be doing the tear down and rebuild myself but letting the painter do the body work prep , There's a lot more work in that than you think ! And you can't be blamed if it goes wrong :wink:
Make sure all your rust eliminating / proofing and under sealing I'd done before hand
Anyway this man is Martin Canavan 085 7842796 065 7071805
Best of luck with it , it's a project I must do myself on the mk2
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Re: Painters.
Postby Merlot man » Mon, 23 May 2016 9:19 +0000
Another painter I thought about is Mick Clancy outside Ennis . I think he now paints aeroplanes in Shannon during the week and does cars at home at the weekend , I had his son In class last year , both gents .
087 9830191
93 na s ltd
Merlot man
