Spoiler
Spoiler
Postby mrges » Fri, 13 Apr 2018 9:49 +0000
I'm thinking very strongly about removing the current spoiler, and then either refitting it or replacing it with something different. Mainly because -
A) It's not fitted correctly (It touches the rear wings and has rubbed the paint off)
B) I'm not particularly fond of it (tho it's not the worst in the world!)
C) I would like the spoiler I had on my first MX5 (if I can find one...and it's not too expensive)
I went out this evening and undid the 4 screws holding it on - but it's obviously (well) glued on as well (Tiger Seal?). Has anyone removed a rear spoiler before? Is there something you can suggest that dissolves the glue (without stripping off the paint!), so I can then try applying pressure and peeling it off (without completely fecking up the boot lid)? If this can happen I can keep the boot lid and decide what option to take. If removing it is going to feck up the lid then I'll need a new lid to work with.
This is what I have at the moment:
Thanks,
Graham
Re: Spoiler
Postby mrges » Fri, 13 Apr 2018 10:07 +0000
Forgot to include this query above.....
When undoing the screws on the inside of the boot lid I noticed this bolt......
I'm just curious, does anyone know what it's for? I couldn't see into the cavity to see what it is attached to (if anything).
Re: Spoiler
Postby 93 Mk1 » Sat, 14 Apr 2018 7:13 +0000
I'm wondering if that bolt was there originally Graham ? Also, I'm wondering if something like a heat gun might soften any adhesive that's on it ??
93 Mk1
Re: Spoiler
Postby mrges » Sat, 14 Apr 2018 11:04 +0000
So that bolt isn't on everyone's MK1 boot then.... Maybe I'll unscrew it and wait to see if the car suddenly falls apart!!
Good idea about the heat gun - I was worried that it might lift the paint from the boot, but might be worth a try.
Re: Spoiler
Postby MX5Spares » Sun, 15 Apr 2018 7:36 +0000
I doubt that big bolt is holding on the spoiler?? You could try the heat method as above but if spoiler was well stuck originally you will be lucky to remove it without paint damage.I suppose try is all you can do really
Re: Spoiler
Postby Pops » Sun, 15 Apr 2018 2:06 +0000
Rub of sandpaper on the underside of the spoiler to give a bit of a gap might help stop the rubbing till you find the spoiler that you prefer
Re: Spoiler
Postby Steve » Sun, 15 Apr 2018 8:01 +0000
Pops wrote:Rub of sandpaper on the underside of the spoiler to give a bit of a gap might help stop the rubbing till you find the spoiler that you prefer
great idea!
Did you try fishing line between the spoiler and boot lid?
Pricey spoiler :
https://www.andysautosport.com/products ... 90012.html
Re: Spoiler
Postby mrges » Mon, 16 Apr 2018 9:38 +0000
Thanks for the ideas. However, the underside of the tips of the spoiler AND the meeting point on the rear wing have already been..... filed and sanded! Trouble is, it was fitted at (slightly) the wrong angle and still hits the bodywork. When closed, it isn't noticeable, but when the boot is opened there's bare metal about the size of a 20c coin showing on the top of the wing.
Steve, I think that is the spoiler I already have on the car (didn't know it cost that much!!)
Re: Spoiler
Postby mrges » Mon, 23 Apr 2018 11:37 +0000
Still looking at spoiler options........ now HERE'S one that catches the eye! (about half way down this page):
https://combustionpunks.co.uk/spad-17-f ... cba1185463
Re: Spoiler
Postby Pops » Tue, 24 Apr 2018 5:29 +0000
It’s got a supercharger fitted but to justify that rear spoiler it’d need to have a jet engine
Re: Spoiler
Postby 93 Mk1 » Tue, 24 Apr 2018 7:19 +0000
Hmmm, there's some questionable tastes on that webpage :)
93 Mk1
Re: Spoiler
Postby Steve » Tue, 24 Apr 2018 10:03 +0000
"You’ve had some recent body Work done, its looking great. Where does your inspiration come from?
To be honest I’ve just winged it and bought items here and there "
LOL
Re: Spoiler
Postby mrges » Tue, 24 Apr 2018 8:26 +0000
:D :D :D :D
Re: Spoiler
Postby mrges » Sat, 05 May 2018 10:51 +0000
OK... after looking at LOTS of variations I've settled (I think) on what I want for my rear end (oooeeerrrr missus). I have no idea what these are called, but this is the type of spoiler I'm looking to replace my current one with:
Can't seem to find one from any of the main suppliers. Have seen two on Ebay, and contacted the seller, but they won't ship (they are based in in UK).
Should you come across one please feel free to let me know :D
Thanks,
Graham.
Re: Spoiler
Postby Pops » Mon, 07 May 2018 1:58 +0000
Would you think of using parcel motel ? I use it for any free delivery to uk eBay items , €3.50 delivery to your preferred parcel motel locker or (€7 I think) for oversized or heavy items to your nearest parcel motel depot.
You can add the motel Northern Ireland address to your PayPal account.
In the meantime why not try some clear vinyl on top of the wings where the spoiler rubs, should stop it wearing away the paint
