Link G4+
Hi guys,
so I know theres a few of you running the LINK ecu's here! talk to me...
I've bought a g4+ for my supercharger build.
just reading through the install manual (http://www.linkecu.bg/downloads/installation/MazdaMiata.pdf) and i know i need to get an IAT sensor (Bosch 0280130085 ordered today).
but what's the story with my 1993 1.6 TPS? is that ok or do i need to do something?
Any advice much appreicated
Tom
2.2.1 Mazda Piston Engine ECUs
Some models supported by the Mazda MX5/Miata/GT-X G4 Plug-In ECU require additional
installation modifications. The following modifications may be required:
Fuel Pump Control – Some models have a switch fitted inside the AFM that disables the fuel
pump when the engine is drawing no air. Depending on the way the AFM is wired it may be
necessary to either bypass the AFM switch or wire a separate ECU controlled Fuel Pump Relay.
Throttle Position Sensor (TPS) – Miata/MX5 1600cc models do not have a factory fitted TPS.
A TPS should be installed and wired to the ECUs expansion connector. This is required for
functions such as acceleration enrichment, idle speed control and motor sport features.
Tom
