Rear Window Heater wiring
Re: Rear Window Heater wiring
Postby charged_rs » Wed, 20 Jul 2011 12:49 +0000
the car wont have a relay
you need an la10 relay - same as the relay for the horn.
the relay plugs into a connector on the rear panel of the boot , near the boot lock mechanism.
the fuse for the wiring will be near the aerial in the boot. the fuse holder will be there but you will probably have to add a 10amp fuse to the holder.
its a 10 min job at most
Postby rockdrummer4 » Thu, 21 Jul 2011 3:28 +0000
Thanks charged_rs, I hope its this simple. So all the witing should be there, just need the relay and the fuse.... BTW its not an electric aerial, if that makes a difference
How do I wire up the relay? should the wires be there, just need to connect them up? sorry if these are stupid questions, dont know anythign about this :)
rockdrummer4
Postby rockdrummer4 » Thu, 21 Jul 2011 7:03 +0000
OK, just checked. their is a black connection at the boot lock mechanism, is this where the relay connects to?
Had a look around the battery and find no fuse box ! Is their anywhere else it could be?
rockdrummer4
Postby rockdrummer4 » Sat, 23 Jul 2011 4:31 +0000
So here's what Im looking at, sorry they r a bit blurred :(
Cant find fusebox around battery at all.. even behind.
Also is this where the relay goes? pic 1061 - into the black and yellow connector?
rockdrummer4
Postby charged_rs » Sat, 23 Jul 2011 11:51 +0000
yes , yellow and black connector is where the la10 relay plugs into
the black connector between the battery and aerial looks like where the fuse box plugs onto
the white 4 pin plug is for an electric aerial.
looks like you need the fusebox bit and an la10 relay , and a hrw switch - the wiring for the switch should be behind one of the blanks to the right of your steering wheel.
all sorted
Postby rockdrummer4 » Sun, 24 Jul 2011 11:08 +0000
Hey charged_rs - thanks alot, so just plug relay and fusebox in and away I go :)
Have the switch already, when on, lights up on dashboard :)
rockdrummer4
Postby rockdrummer4 » Fri, 05 Aug 2011 9:37 +0000
Thanks charger_rs - all working now. Plugged in relay and fusebox,
tested this moring when rear window was all fogged up - and what'd ya know, it cleared :)
rockdrummer4
Postby charged_rs » Fri, 05 Aug 2011 12:34 +0000
good stuff
glad to help
