Player or Speakers ??????
Postby jack » Wed, 02 Feb 2011 2:59 +0000
Advice Please. Mk2 1998 :lol:
My question is quite simple. When the sterio ( radio or cd) is on and I turn up the volume, the noise turns into a loud Buzz/vibration/ distortion noise. But not electrical feedback.
The CD player ( Pioneer) jumps, when we go over big bumps. :oops:
Ive looked at the door speakers. Drivers side looks original, but vibrates as if there is a tear in the speaker ( can't find one) . Passenger side is smaller and held to the door with cable ties ! :x
What do I change first? Speakers or Player ?
Advise on what to buy ? :D
To Feel Is To Believe !
jack
Re: Player or Speakers ??????
Postby johnc55 » Wed, 02 Feb 2011 4:20 +0000
Jack,
I had the buzzing speakers when I first got the car. The well documented wet/damp original Bose speakers. I also had an original Bose headunit.
I replaced the headunit and continued to use the original Bose amp and speakers. Aux line output to the amp - not the speaker outputs. The speakers would still buzz in damp or wet weather. I then replaced the speakers and bypassed the amp (but used original wiring)
Sound now satisfactory.
The reason for the long story is that it may depend on whether there is an original Bose amp and speakers still being used in your car. My advice would be to go for a new set of speakers - not expensive and suitable for the output of your headunit. Make sure to bypass the original Bose amp (if there is one) because the speaker output from this is not what you want to feed into your standard speakers. (The Bose amp drives the Bose speakers with an unusual power range which will damage standard speakers. Similarly, the output from the headunit speaker connections will not work through the Bose amp.)
Good info an Miata.net garage.
Also worth making up a drip shield for the speakers from tupperware bowls. Stops them getting wet from washing or heavy rain dripping past the window seals. I have a template somewhere for making a door mount suitable for standard 5" or 6" speakers)
Hope this is of some help. Give me a shout if you want to pick my brains - whatever is left of them!
JohnC
johnc55
Postby jack » Wed, 02 Feb 2011 10:30 +0000
Thanks John... :lol:
johnc55 wrote:Jack,
JohnC
jack
Postby bren » Thu, 03 Feb 2011 11:28 +0000
The radio jumps when you go over a bump probebly because there is a piece missing at the back. In the section where the radio fits there is a piece of vertical flat metal with a hole in it. There should be a piece of rod that attaches to the centre of the rear of the radio. This rod along with a rubber cover inserts into the vertical metal. I know this because mine was missing and everytime I went over a cats eye my cds hopped. Either that or its not secured at the front.
Get new speakers and cover the back with plastic to stop them getting wet.
We are only immortal for a limited time
bren
