Rear Window Heater wiring
Postby rockdrummer4 » Wed, 30 Mar 2011 3:12 +0000
Hi Lads,
Have a 1998 1.6 MK1, with a new hardtop. The connector on the hardtop does not plug into the car connector.
The colour of the wires are as follows:
CAR - Yellow, Red / White, Black
HARDTOP - White, Black, Black / White
Any help with what wire goes with what would be great. Aint gonna fork out €80 or so for connector, am thinking if I can get wiring done can use one of these: 250V 10A IEC 320 C14 Plug to C15 Socket Power Connector.
Also, not sure if it is all wired up correctly. Have switch on order from mx5parts, gonna plug this in and get the wiring above done and hope for the best. I have looked for the relay and the fuse but cannot find them, but am assuming as their are wires coming off the connection on the car they must go somewhere, so Im hoping its all there !!:)
rockdrummer4
Re: Rear Window Heater wiring
Postby leamyj » Wed, 30 Mar 2011 5:26 +0000
Buy a few spare fuses, try a few combinations, you might be lucky and get it first time :mrgreen:
Postby rockdrummer4 » Thu, 31 Mar 2011 7:29 +0000
Hey, I would prefer not to :) I have an idea what wire goes with what just would like someone to confirm :) Thanks
rockdrummer4
Postby Steve » Thu, 31 Mar 2011 11:48 +0000
rockdrummer4 wrote:Hi Lads,
I think your hardtop might be a mk2 hardtop, the mk1 car's connector wiring is :
Black (ground)
Red/White (heater element through relay)
Yellow (switch)
Also, you'll need the wee fusebox (it plugs in over near your aerial/battery, might be there already) and a relay, its behind the carpet in the boot on the inner edge behind the license plate.
Postby rockdrummer4 » Thu, 31 Mar 2011 12:18 +0000
It is a MK2 hardtop, my old MK2 got robbed at the beginning of March, so replaced it with the MK1 and was able to use the hardtop from it (car was too damaged to repair :(
I was just hoping that because the connector is present in the car, the whole wiring would already be there !!
However, if the fusebox is not there how do I connect it? And also the relay, how do I wire this in?
I see both the fusebox and relay on mx5parts but do not know what to do with either :) A step by step guide would be nice :)
rockdrummer4
Postby rockdrummer4 » Thu, 31 Mar 2011 12:22 +0000
Hey Steve,
So the wiring you mentioned is what I have on the car:
Black (ground)
Yellow (switch)
So now what does this correspond to on HARDTOP - White, Black, Black / White
Thanks for your help.
rockdrummer4
Postby mx5ash » Thu, 31 Mar 2011 12:49 +0000
This is what you'll have to do with the relay
http://www.mx5nutz.com/forum/index.php?showtopic=47700
Postby Steve » Thu, 31 Mar 2011 3:13 +0000
rockdrummer4 wrote:Hey Steve,
Black (ground)
Yellow (switch)
I don't know for sure, the NB car side harness has different colours to those (is it a Mazda hardtop?).
Basing it totally on colour I'd GUESS it would be something like :
black - ground
black / white - switch
white - relay
I'll take pics of the relay/fuse locations later on my car so you can compare.
Postby rockdrummer4 » Thu, 31 Mar 2011 3:27 +0000
It is a genuine mazda hardtop from mx5parts.....
The pics would be a great help... thanks. If all the wiring isnt there is it just a matter of running a cable from the + on the battery through fuse, then relay, then 3 wires coming out of relay and connected as below? Guessing:
CAR Hardtop
Yellow - black / white Switch
Red / White - White Relay / heater element
Black - Black Ground
Using fusebox and relay like in link: http://www.mx5nutz.com/forum/index.php?showtopic=47700
rockdrummer4
Postby aquarian5 » Thu, 31 Mar 2011 6:08 +0000
Sorry for stating the obvious....but sometimes the car connector has a dust cap attached on it....just presuming this has been removed.
John.
Postby Igor » Thu, 31 Mar 2011 6:51 +0000
Hey, I have an Mk1 hardtop on my Mk2 5 and the same problem so I'll be happy to swap the cables with you. Let me know if you're interested. I'm in Dublin but could post it, no problem.
Igor
P.S. I didn't bother with changing the cables, I just took the connectors off the heaters, since it's done only twice a year I didn't bother with the cables.
Igor
Postby johnv » Thu, 31 Mar 2011 8:32 +0000
i have a mk 1 car and a mk 2 hard top same problem did not connect heater but hope to get it sorted for next winter
johnv
Postby Steve » Thu, 31 Mar 2011 8:53 +0000
Apologies for the pics, bad light.
This is the wee fusebox behind the battery :
You can see the relay here behind the carpet panel in the boot (middle left of pic with white base)
Postby rockdrummer4 » Fri, 01 Apr 2011 7:13 +0000
Thanks for the pics Steve,
Did ya have to remove battery to see fusebox? Had a look for relay but could not find it... Will have to trace back cables from connector on the rear shelf to see where they go in the boot :)
Aquarian - no dust cap....
rockdrummer4
Postby rockdrummer4 » Wed, 20 Jul 2011 8:21 +0000
Am not having much luck with this :(
Left the car into Mazda garage for service, asked him to take a look at HRW. He said it would be a big job to trace the electrics i.e. have to take out seats etc :0
Is this right? I thought 98 models already had the wiring? It has the connection at the back passenger shelf, and I have the cable that connects the roof to this connection ! Does this mean that just this connection has to be wired up to the battery?
rockdrummer4
