Thermostat Leak
Thermostat Leak
Postby graham » Fri, 05 Jun 2009 3:21 +0000
I noticed I have a leak from the thermo stat today, it's coming from the metal pipe connected to the housing of the thermostat, not the rubber pipe connected to it.
Any ideas, how concerned should I be?
Graham
graham
Re: Thermostat Leak
Postby Steve » Fri, 05 Jun 2009 5:10 +0000
Get some JB weld (fab stuff!) and seal it.
Re: Thermostat Leak
Postby graham » Fri, 05 Jun 2009 9:24 +0000
Thanks Steve
g
graham
Return to Leaks
