Wet Seat belts
Wet Seat belts
Postby T42 » Fri, 19 Jun 2009 11:57 +0000
Does anyone know how and where the water gets into the seat belt housing as the belts are soaking. Is there a link to the drain holes and seat belts? Or is there another source?
Tomas
T42
Re: Wet Seat belts
Postby Steve » Fri, 19 Jun 2009 1:31 +0000
Hi Tomas,
Have you cleaned out the drain holes behind the seatbelt "towers"?
See this thread for pics :
http://forum.miata.net/vb/showthread.php?t=330455
Re: Wet Seat belts
Postby T42 » Mon, 26 Apr 2010 6:49 +0000
Wet seat belt mystery finally resolved! Replaced the softop and found a broken tape cassette cover that sat on the drain hole. So even after clearing the drains from below the water was still filling up and wetting the seat belts! Dry seat belts at last!
T42
Return to Leaks
