hood cables
hood cables
Postby sabik » Tue, 01 Dec 2009 12:11 +0000
Is it easy to fit hood cables with out removing the hood or has anyone tried?
http://www.mx5parts.co.uk/product_info. ... cts_id/451
Glen
sabik
Re: hod cables
Postby Steve » Tue, 01 Dec 2009 12:22 +0000
Its possible, but a PITA
Re: hood cables
Postby sabik » Wed, 02 Dec 2009 9:31 +0000
Thank, I think I miight give it a go.. the hood its self is on good nick only one nick worth talking about.
Oh and got the Dandycar.com dvd on hood changing and think it's quit good it made me aware of things I wasn't aware of and a very good idea how to change a roof and the things you need to do it. Would still like to see one beening done so anyone thinking of it keep me in mind. Have a friend planning to do one soon but its there first time. Plan on giving them a hand and see how that goes...
Glen
sabik
Re: hood cables
Postby Steve » Wed, 02 Dec 2009 10:19 +0000
did the cables snap?
Re: hood cables
Postby sabik » Wed, 02 Dec 2009 2:27 +0000
yes! :( so hoping I can fit new ones with out replacing the whole lot!
Glen
sabik
Re: hood cables
Postby Steve » Wed, 02 Dec 2009 6:38 +0000
hmm.. yeah,
remove the metal brackets on the front lip of the hood, then the rubber seal nearest the front corner and the metal bracket under it.
If you put your hood halfway up you might get enough slack to pull the front corner edge off the frame (you'll see what I mean ;-) ).
You should be able to drill out and replace the cable on this end, then thread it through and attach to the spring behind the drivers/passengers head.
Re: hood cables
Postby sabik » Wed, 02 Dec 2009 11:47 +0000
That was kinda my plan... from a quick look at it in the dark :roll:
Have you done it yourself? Will i need a rivet gun and rivets I think it might be worth getting then for hood changing in the future anyway.
Glen
sabik
Re: hood cables
Postby Steve » Thu, 03 Dec 2009 12:20 +0000
yeah, have changed a fair few roofs in the past. Easy enough.
Re: hood cables
Postby sabik » Thu, 03 Dec 2009 9:19 +0000
I'll post a few shots on how it goes! :?
Glen
sabik
Re: hood cables
Postby sabik » Mon, 07 Dec 2009 9:35 +0000
got those cables! and have them ran through the roof wasn't the end of the world... Just used a opened out close hanger. Did have to open the roof a little to get into the rivets but just been carfull got there. only problem is I hadn't got the right size rivet. So to the shops today the will hope to finish off the job this evening. Then the job should be oxo!
Glen
sabik
Re: hood cables
Postby Steve » Mon, 07 Dec 2009 11:00 +0000
great stuff!
Return to Leaks
